12-06-2017, 12:08 PM | #1 |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
Let's talk about TWIN CHARGING!
Not that I'm going to do it... But I have been thinking about it. I have a brand new TVS1320 that's been sitting on the shelf for a few years looking for a home... The thought has cross my mind to stick it on the intake side of the LTG...
Food for thought, the Volvo S60 is now a 2.0 that is twin charged (both supercharger, and turbocharger), putting out 362hp and 347tq... Now there are a couple ways a guy could go about twin charging, a compound boost setup, or you can run them independent of each other with some creativity. I'll talk about compound boost first. So when compound boosting, you're feeding the turbocharger boost directly into the supercharger. From what I've found, this essentially multiplies your boost from the TC (turbocharger) and the SC (supercharger). There is a formula based on the pressure ratios you can use to figure out the final boost number, but I won't get into that, instead I will post this handy chart... So in theory, you can run both the SC and the TC in their maximum efficiency zones without running either one by itself so hard its into an inefficient range to get a big boost number. So for example, looking at the chart above, you can run the SC at 8psi max, and the TC at 8 psi max, and the final number will be 20.35 psi (around stock), while creating less heat from either the SC or TC, and probably way less than just a stock TC trying to push 20+ psi Then, running them independently (non-compound), there is generally a diverter valve/flap of some kind that will switch the boost input to the engine from the SC to the TC. You run that SC at low rpm to get instant boost, power and TQ, and when it runs out of steam, the valve will switch the air tract so that the TC boost takes over for that top end power. MY thought on this, to keep that simple, assuming it would work would be this... Most new age superchargers have a bypass valve that opens while an engine is idling... Assuming you plumb the TC right into the inlet of the SC, my thought is that when you want the TC to take over, have the bypass valve open to bypass the SC rotors and straight into the intake... This should relieve most of the compound boost effect easily, without all the extra BS. Either way, in theory, you're getting instant boost off the line on low rpms with the supercharger where you would normally experience the turbo lag, and you get the top end pull of that turbo, while not running either the TC or the SC past it's point of max (or at least good) efficiency. Thoughts? |
12-06-2017, 01:08 PM | #2 | |
This guy took a lotus and twin charged it..couldn't we follow a similar build? But refine it further
12-06-2017, 02:55 PM | #3 |
Drives: 17 SS a8 Join Date: Feb 2010
I have considered this but more along the lines of a zl1 with a giant turbo added. People have done it in the past with supercharged cobras but have poor results. They actually report making more power after pulling off the blower.
I think they are using way too small of turbos and the same thing would happen to the stock Camaro turbo. It isn’t designed to flow tons of air at low boost. If your going to size a turbo for a zl1 you would want to consider that engine to be more like a 10.4L engine. 6.2L at 10psi from the blower would act like a 10.4L engine from the turbos perspective. Normally if you wanted 1200hp a pair of 62mm turbos would be fine but you would never put anything that small on a 10.4L engine. They would choke off the engine. I can post up some turbo maps when I get home and it will make more sense. I would love To take a zl1 and put a couple of 80mm or larger turbos on the thing.
dropped a valve in the 6.2. now running a drop in rods and piston 5.3
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
12-06-2017, 03:31 PM | #4 | |
Drives: 2013 ATS M6, 95 Z28 Conv M6 turbo Join Date: Apr 2017
If the goal is to make the same power, lets say 270hp from 2.0L turbo4, then you can do it with (say) 18psig from a turbocharger, like we do, or twin-charge - so maybe 7.5psig from the turbo and 7.5psig from the S/C.
The engine will see similar intake velocities and pressures and intercooling being equal make the same max power - but you're still flowing the same CFM through the turbo, just compressing it less (assuming you change your A/R for this to optimize the curve!). The advantage is at 2000rpm when you slam on the throttle you're pretty much instantly at 7.5psig already from the S/C, so your powerband is wider and flatter and throttle response is better as the turbo then (quickly... very quickly) catches up. Volvo just decided their turbo4 would be ~350hp and didn't want it to feel peaky or have tons of lag like a single large turbo would. Ford, when faced with the same problem, increased displacement. W-Body guys have done this too, trying to turbocharge the 3.8L S/C and the results are consistent that if you want more raw power you're better off with a single large turbo or supercharger than the complications and headaches of twin-charging. Same with twin-turbo engines as well. For a street driven daily driver, a positive displacement blower is my favorite power adder. Their "instant power" is pretty nice. In the case of the LTG I'd rather stroke the engine an then put on a slightly bigger turbo through. Quote:
12-06-2017, 03:32 PM | #5 |
Drives: 2018 2SS Join Date: Oct 2017
we have done this in the past with both the GTP, and the LSJ supercharged cobalts. mixed reviews really, but ill tell you that both cars were substantially faster after pulling the blower off. i have driven several twin charged cobalts that made north of 500 WHP, and was not terribly impressed (compared to a strictly turbo only setup). its really hard on parts, overly complex, and just generally works better on paper than it does in any practical application.
with an unrestricive intake manifold, and a "good" supercharger, i would expect results to be considerably better than blowing through crappy old gen 3 M90s like we were doing many many moons ago. my vote: a properly sized turbo, and a tiny shot of the sauce to get you out of the hole |
12-06-2017, 04:54 PM | #6 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Yes!!
2017 1LT RS I4 A8 BLACK ON BLACK
Kindness and compassion #OthersFirst |
12-07-2017, 07:28 PM | #7 |
Drives: 2017 l4 blue 6speed Join Date: Oct 2016
To help super low endrpm for the s.c, mercedes, designed the m60 ? To be clutch driven to only engage above 1800rpm to help with the motor at idle being it was a 4 banger
12-11-2017, 03:01 PM | #8 |
OK... So good for exotic builds, mainly for eye candy at shows... Probably not so great for performance. Scrap that idea.
12-12-2017, 01:05 AM | #9 |
Drives: 2017 Camaro; 2017 Acadia Denali Join Date: Jun 2016
Yeah, unless you're an OE manufacturer with an unlimited R&D budget, no one is twincharging an LTG. This is exactly why ZZP sells a block off plate for the M90 supercharger that comes stock on the L67 engines. You remove the OE drive coupling & rotors, then replace with the block off plate.
This is in no way a personal attack or confrontation, and is not necessarily the view
of the management or sponsors, and the thoughts contained herein are mine, and is not intended to hurt anyone's feelings or ruin their delicate self esteem, or to invalidate anyone's personal views or thoughts, nor is it a condemnation of anyone's race, religion, sex, sexual preferences, handicaps, or intellectual abilities. |
12-23-2017, 07:34 PM | #10 | |
Drives: Chevy Camaro Join Date: Dec 2014
12-23-2017, 10:31 PM | #11 | |
