05-08-2023, 07:27 AM | #1 |
Drives: 2012 Camaro SS Join Date: Apr 2016
Starting Issue - Cold and Hot
I've researched the forums and noticed the common hot start issue but my problem is a little different and I'm looking to see if someone has found a fix or has any ideas.
Car cranks for a long time before starting. When it starts I get the crank position sensor code as well as all the stabilitrak lights and no tachometer. This happens cold or hot the same way. Battery is brand new and I tested the voltage of the battery when the car is running and not. Voltage rises as it should when idling so I suspect alternator to be fine. My assumption is the long crank drains power resulting in the tach and stabilitrack issues. Please let me know if anyone had a similar issue on cold starts. |
05-08-2023, 03:50 PM | #2 |
Drives: 2010 Camaro SS/RS Twin Turbo Join Date: Dec 2022
I would fix that Crank sensor code first.That would cause the tach to go out also.Probably just a crank sensor.
2010 Camaro SS 416 Twin Turbo,4L80E trans,ZL1 rear.1065 rwhp.9.03@154 1/4 mile so far.
05-09-2023, 08:41 AM | #3 |
I dont believe its the actual crank sensor. I dont get that code every time and if I clear it, it stays off for the rest of the drive.
Update: I added the secondary ground in the trunk and will be adding the secondary ground between the engine and frame today. No change after the trunk ground was added. |
02-03-2024, 12:40 AM | #4 |
Drives: 2013 Camaro 2SS Join Date: Dec 2015
Did you end up fixing this issue? I am experiencing the same issue even after replacing the crank sensor, and adding the extra ground from the engine to the frame.
2013 Camaro 2SS: Summit White-Mojave Leather Interior : K&N CAI : Pypes Bomb Axle-Back Exhaust
02-16-2024, 05:37 PM | #5 |
Did u do a crankshaft variation relearn procedure with a scanner after replacement? This needs to be done!
alternator, battery, cold start, crank position, stabilitrack |
