BeckyD @ James Martin Chevy
Old 04-03-2023, 07:18 AM   #1
dfxrte
Drives: 22 ZL1 M6
driver side rear wire harness
hi all,
swapping new wheels on shortly, I have heard mixed things on this topic.
Has the wire harness been relocated to prevent rubbing when going larger wheel setup? I have heard GM relocated it after 2020 (?) not sure on the year.
Is it something to still look at on a 2022 zl1, going 11.5 on the rears with the stock 305 (for now)
Sold: '17 m6 2SS [arctic blue]
Current: '22 m6 zl1 [vivid orange]
https://ibb.co/qpWHXZM][img]https://i.ibb.co/NKm0Q46/zl1.jpg
dfxrte is offline   Reply With Quote
Old 04-03-2023, 08:12 AM   #2
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Not sure but it's pretty easy to remove the fender well liner and take a look while the wheels are off.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 04-03-2023, 08:31 AM   #3
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
I had my 23 opened up and I looked at it and didn't see a potential problem. I have 305/30/20 OE sizing and just decided to look since I was in there and have no plans to go wider in the future.
WhiteMale is offline   Reply With Quote
Old 04-03-2023, 10:21 AM   #4
clg82
Drives: 2020 Camaro ZL1
I went to relocate my harness on my 2020 for the 1LE wheels and tires and it was already relocated from the factory.....like others have stated it's a quick look and it's easy to do in your garage if you're worried about it.
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21
clg82 is offline   Reply With Quote
Old 04-03-2023, 08:38 PM   #5
dfxrte
Drives: 22 ZL1 M6
right on thanks yall. will check next month when the wheels come in
Old 04-04-2023, 06:19 AM   #6
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
https://www.camaro6.com/forums/showthread.php?t=586572
LiqTenExp is offline   Reply With Quote
Old 04-04-2023, 10:24 PM   #7
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
Great info, had no idea that GM potentially moved the harness already.
Schlok is offline   Reply With Quote
