11-02-2016, 08:59 AM | #1 |
Drives: 20162sscamaro Join Date: Mar 2016
Why is mine slower then as advertised?
Hello.
My dyno results were low, around 345hp/350tq. I wasn't concerned about the low numbers due to the fact that dyno's don't mean much on there own. However the best 0-60 time is 4.5 after about 12 runs over a few days. Then my 1/4 mile best is 13.1. The conditions were decent for ripping, I was going down hill slightly on the 1/4 even lol. I don't get it, I'm in launch control mode in a a8, I run premium 91 octane gas but I think I'll run 94 octane from now on perhaps? I heard the fuel in the general area was terrible. I'm roughly 1000ft in elevation and my tires are good, 7000kms on my car, just changed the oil (first 4 are free) put in the max psi at 51 to avoid flat spots and stored it for the winter....damn Canadian winters. I almost wanna go to the dealer and bring it to their attention for a possible explanation. It would be nice to 'test drive' one from the lot. What do you guys think? |
11-02-2016, 09:01 AM | #2 |
Drives: 2016 Camaro SS Join Date: Oct 2016
Which dyno was used? Were the results SAE corrected?
11-02-2016, 09:25 AM | #3 |
Superflow windyn V3.2 Not 100% sure on the corrected part but the guy said its real world numbers. The curves looks like it's suppose to those, nice and flat tq curve!
11-02-2016, 09:29 AM | #4 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
Also, these times that are quoted, are based off of a prepped surface, and after the driver does a burnout to heat up the tires. Both of these also give better grip. |
11-02-2016, 09:29 AM | #5 |
^Name^ | Things I Say -->
Drives: 2016 2SS Convertible, Hyper Blue Join Date: Oct 2016
What's the altitude where you were doing your 1/4 mile? Is that number from the dash timer, a friend with a stopwatch, or actual traps?
11-02-2016, 09:32 AM | #6 |
Drives: 2014 2LS (traded in) 2015 1SS 1LE Join Date: Apr 2015
How many miles are on the car? Initial break in is 1500 as per GM but you'll continue to loosen up and gain power until about 7-8000 miles.
11-02-2016, 09:36 AM | #7 |
Snackbar Tuning
Is your Driver Mod working properly? Were you at the track or on the street using the cars dash timers?
11-02-2016, 09:43 AM | #8 |
what gear was used on the dyno?
what was the mph in the 1/4? |
11-02-2016, 09:58 AM | #9 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Without knowing trap speed, 60' and DA, not to mention driver skill, just being told a 1/4 mile time is meaningless...
If you are spinning to a 2.2 60' in 3000 DA and you are a novice driver the 13.1 makes total sense. |
11-02-2016, 09:59 AM | #10 |
davet
Drives: 2016 2SS Mosaic Black Join Date: Apr 2010
Something isn't right. I've seen numbers that were a little low, but nothing that low.
As far as fuel make sure you run a top tier gasoline. Here is a list. This site has some other good information also. Top tier gas is more about long term benefits though. http://www.toptiergas.com/licensedbrands/ I would use a top tier gas also find a busy station, sitting in a stations tank for a long period of time doesn't do gasoline much good.
Replacement car ordered 2/02/2016
2/03/16 2500 2/04/16 3000 no TPW 2/8/16 3000 TPW 2/29 2/18/16 3400 3/3/16 3800 3/4/16 4B00 3/5/16 4300 3/7/16 4200!!! |
11-02-2016, 10:14 AM | #11 |
Drives: 2017 2SS Join Date: Jul 2015
I'm in Kelowna and i find Chevron 94 to be the best gas we can buy here in BC. I run it in my 2013 GSX-R 750 and it makes a noticeable difference over Shell 91 for example. It's also the highest octane you'll find in B.C. Give that a try.
11-02-2016, 10:19 AM | #12 | |
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
11-02-2016, 10:37 AM | #13 |
Drives: 2017 Corvette Stingray Grand Sport Join Date: May 2015
Why is your check engine light on?
11-02-2016, 10:54 AM | #14 |
0 RPM, it's not running.
