TireRack
Old 01-05-2015, 12:36 PM   #1
eldub
eldub's Avatar
Drives: 2014 BLK/BLK/BLK 2SS 1LE
Best way to muffler delete when you already have a cat-back system?
So I got the Magnaflow comp cat back on my '14 1le this summer, I was really disappointing in the volume, so I got bored today and pulled the axle-back part off.....LOVED IT!!!! Not putting the mufflers back on so what is my best option to muffler delete? Are there delete pipes to match up to the 3" pipes or should i get a muffler shop to cut out the mufflers?
eldub is offline   Reply With Quote
Old 01-05-2015, 12:43 PM   #2
djpelosi
djpelosi's Avatar
Drives: 2010 Camaro 2SS/RS
Cheapest route would be to have a muffler shop cut off the mufflers and weld in new pipe to replace. They will also have to cut the tips off the mufflers and weld them onto the new pipe. Will probably cost around $200.
2010 Camaro 2SS M6
2" Stainless Power Longtube Headers
3" Full exhaust w/ Off-Road H-Pipe
Bo White Ported Throttle Body
Hurst Short Throw Shifter
Best Time: 12.43 @ 114, 1.99 60' on stock wheels and stock tires
Build Thread
djpelosi is offline   Reply With Quote
Old 01-05-2015, 12:55 PM   #3
Burt
Cone Killer
Burt's Avatar
Drives: 2012 SS
^This. I had a local shop give me an estimate to do a muffler delete on my stock system, and it would have been around $100. Not bad at all.
2012 Camaro SS - Sold
Selling off my remaining wheels, tires, 27mm front sway bar, and MGW shift knob. Get them out of my house before my wife puts me out!
Burt is offline   Reply With Quote
Old 01-05-2015, 01:30 PM   #4
steakmaker
steakmaker's Avatar
Drives: '10 Camaro SS,Jeep Commander Hemi
muffler delete
You can get a set of SLP loudmouth pipes, in place of your mufflers . 3" pipe that goes to a 4"polished tailpipe,or you can put the twins back on.The system is all stainless steel and comes with oem type clamps.
steakmaker is offline   Reply With Quote
Old 01-05-2015, 02:34 PM   #5
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
IMHO ,you should decide if you will ever install long tube headers first B4 you dump the Magnaflow muffs .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 01-05-2015, 03:06 PM   #6
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Solo axel back. No muffler, no drone, great sound. Best of all worlds.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 01-05-2015, 05:17 PM   #7
eldub
eldub's Avatar
I'm thinkin it might be easiest to just gut the mufflers, if they had center inlet and outlet it'd be fine but they're side in center out so i'd probably be gettin an slp loudmouth made by a muffler shop if i go that route, was really hoping to not dump another 4-500 into it
Old 01-23-2015, 09:07 PM   #8
InfernoB
Drives: Camaro 2SS RS L99 Blk with IOM pkg.
Magnaflow Axleback 15308! Will bolt right up to your existing magnaflow Catback in place of the axleback portion you removed. Alaso has 4 1/2" tips! No need in hacking & mismatching a nice Catback? Then if you get more aggressive mods later, you can switch the axleback portions… This axleback kit is a muffler delete kit!
InfernoB is offline   Reply With Quote
Old 01-24-2015, 01:55 AM   #9
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
I paid $70 to have the muffler delete done lol
2011 2SS/RS built 8/24/10
Old 01-24-2015, 07:57 AM   #10
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
Just know, longtubes without cats and no mufflers will be loud
-John S.
grocerygetter is offline   Reply With Quote
Old 01-24-2015, 09:44 AM   #11
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
This....I have that exhaust ...really nice no drone.
rontammy0 is offline   Reply With Quote
Old 01-24-2015, 12:49 PM   #12
Orange 2010 Camaro
Orange 2010 Camaro's Avatar
Drives: 2010 2SS/RS Camaro
One note of caution, those super cheap muffler shop $100.00 or less, axle back systems more than likely are NOT going to be 304 or 409 stainless tubing,& in no time at all, you will be looking at RUST!
Most of your average muffler shops do not have the machine to bend stainless steel tubing. You can buy the short bends & elbows from stainless works with the ends expanded for a SLIP FIT to fabricate your own system.
l had a Borla system left over from a 2003 ZO6 Corvette that I used sections from, & it the sounds fantastic with NO drone!
Attached are a few photo's of my system before I added the exhaust hangers & the 4 in tips.
All the best,
Orange 2010 Camaro
Orange 2010 Camaro is offline   Reply With Quote
Old 01-24-2015, 12:52 PM   #13
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
Electric cutouts would be a good option, you have loud when you want it and quiet when you need it.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 01-25-2015, 10:10 AM   #14
rontammy0
All the best,
Orange 2010 Camaro
I have the magnaflow flow muffler delete. There was a Camaro for sale at a local car dealer. It hade the cheap muffler delete. The pipes that replaced the mufflers rusted already. When you stood behind the car and at the exhaust ..it looked terrible.
