TireRack
Old 01-25-2015, 12:20 AM   #15
SSeniorMoment
Drives: 2010 2SS/RS LS3 A6 IOM
I've asked myself that question, did a lot background and corresponding with very knowledgeable forum members, plus the builder. ...going VVT with PRC heads. The builder will use Ed Curtis to spec the cam and Lunati to do the grind. I understand another old quality cam grinder (Crower) is increasing production on their custom LS family of custom grinds. I'm the Lunati grind will be in the 231/240, .63x/.62x range. Not sure where the Circle D stall will be, but the whole package will be a kick in the pants.
SSeniorMoment is offline   Reply With Quote
Old 01-26-2015, 12:23 AM   #16
DuhKoDuh
DuhKoDuh's Avatar
Drives: 2011 Camaro 2SS/RS (Black) L99
Originally Posted by Tampa Tuning View Post
My results from an L99 conversion to the LS3 with 3.91 gears
What all did you have done in this dyno sheet?
Follow me on Instagram @C7Corvettes
DuhKoDuh is offline   Reply With Quote
Old 01-26-2015, 12:24 AM   #17
DuhKoDuh
DuhKoDuh's Avatar
Originally Posted by Pro Stock John View Post
I have GPI VVT SS3, Bo White ported heads. Car has 3200 converter, 3600 would be a better match. Stock gear would be okay but I have a 3.91
Sounds healthy, what exhaust?
Old 01-26-2015, 02:45 PM   #18
Jason 98 TA
Drives: Camaro
Did you checkout the TSP grinds? The VVT-3 & VVT-4 both make over 100 flywheel hp gains! I'd easily put either against anything available on the market. They were both engine dyno developed & you can add cnc porting of your heads on exchange for $750 on special!! Not only that but we will also mill your heads to the desired compression to match the camshaft!!
http://www.texas-speed.com/p-260-tsp...t-package.aspx
Jason 98 TA is offline   Reply With Quote
Old 01-26-2015, 02:46 PM   #19
Jason 98 TA
Drives: Camaro
Here's a VVT-3 with no other mods! This is rear wheel hp. Engine dyno was right at 100hp!!
Old 01-26-2015, 09:05 PM   #20
dishonored
dishonored's Avatar
Drives: 2012 Camaro SS/RS
Big Cams for my L99?
dishonored is offline   Reply With Quote
Old 01-26-2015, 10:04 PM   #21
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
The gpi vvt ss3 made over a hundred to the wheel on mine...not flywheel. I think the tsp VVT cams are good for sure...but the gpi grinds are great as well.
-John S.
grocerygetter is offline   Reply With Quote
Old 01-27-2015, 10:35 AM   #22
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Kooks long tubes
Catless
Jegs X pipe
Hooker Maxflow mufflers (I don't like it super loud but I still like having that flow)
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
Old 01-27-2015, 10:13 PM   #23
BLACK10
BLACK10's Avatar
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60'
Who doesn't like idle vids!
NightFury VVT
Nightfury LS3 conversion
BLACK10 is offline   Reply With Quote
Old 01-27-2015, 10:34 PM   #24
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Originally Posted by Bo White View Post
Oh no. I'd be running a 3200 on a stock cam if I had a L99.
I did that for a while... works great...
Old 01-27-2015, 11:27 PM   #25
Snidely Whiplash
Fight Crime, Drive Armed
Snidely Whiplash's Avatar
Drives: '14 2SS Yelo Maro, HD collection
Call an expert/shop and answer their questions. Have plenty of coffee ready, because there's MANY questions to be answered. You plans for the car 5 years from now do not count. NOW is the questions to be answered. You likely find you're gonna need a few thousand more than what a cam would cost. Big cams/stock motors/chassis = disappointment.
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
Snidely Whiplash is offline   Reply With Quote
Old 01-28-2015, 05:17 PM   #26
Pro Stock John
Writer
I have what I would call a big cam, and while my local tracks are not open, I will say that this car is really fast now. I've had a past car that went 10.9@123 on motor and I think my car has it in it right now.
PROJECT HEAVY CHEVY
Old 02-12-2015, 11:33 AM   #27
DuhKoDuh
DuhKoDuh's Avatar
Originally Posted by BLACK10 View Post
NightFury is a 233/242 113LSA. Available in LS3 conversion or VVT
Let me know if I can help you further.
Nick
Emailed you, Nick, just waiting on a reply.
Old 02-12-2015, 12:01 PM   #28
digdeep0169
digdeep0169's Avatar
Drives: 2012 Camaro SS 45th Anniversary
my L99 with Comp Cam LS3 Custom Grind 235/244 on a 112 w/ .621/.612, 3.91 gears, factory stall converter, Long Tube Headers w/ o no cats, will do 3200 stall soon to aid in the "bucking" of daily driving:
Love it!!
~ 2012 SS ~
digdeep0169 is offline   Reply With Quote
