09-30-2019, 09:56 PM | #1 |
Drives: '23 Hyundai Kona N, '24 VW GTI Join Date: Aug 2019
SS 1LE First Time AutoX - PTM Modes?
I am going to be running BS at Marina next weekend. I have never done an autocross or track day. Just karting (KT100) at Blue Max, Dixon, etc. Should I just go out in track mode with all the nannies on, or play around with PTM?
10-01-2019, 06:54 AM | #2 |
Drives: 2017 SS 1LE Join Date: Oct 2015
You could start with PTM race, will be too intrusive, best is to turn all nannies off.
I'll be there in a Silver SS 1LE. Last edited by JRL1LE; 10-02-2019 at 10:29 AM. |
10-01-2019, 09:41 AM | #3 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
BS? Isn't SS 1LE classed AS?
In any case I'd go to track mode, then switch all nannys off by holding down the button until the stabilitrak off light comes on in the dash. AutoX has no real penalties for getting it wrong and IMO learning to drive the car with the nannies on may lead to some bad habits, even if it may be faster at first.
10-01-2019, 12:59 PM | #4 |
Drives: 2018 2SS 1LE in Nightfall Gray Join Date: Jul 2018
Even in PTM Race you will get some throttle interference. Track mode if the lot is smooth, sport if it has a lot of uneven surfaces and all the nannies off
10-02-2019, 01:40 AM | #5 |
10-02-2019, 01:43 AM | #6 | |
10-02-2019, 07:55 AM | #7 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Congrats on taking out the car. Too many of them sit around in garages. I would suggest for AutoX, you run with everything off. AutoX really is about learning car control and it's a lot more fun (and confidence inspiring) to do that in a parking lot where your biggest worry is hitting a cone or two. My preferred AutoX setup is: Steering in: Tour Suspension and Throttle in: Track Then once in Track, hold the button down until both dash lights are illuminated. You are now 'all off'. I also run with the AutoX calibration in my eDiff, and it is only active when in Track - all off. Have fun!
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
10-02-2019, 12:18 PM | #8 |
10-02-2019, 12:19 PM | #9 |
10-02-2019, 12:21 PM | #10 |
10-02-2019, 12:29 PM | #11 | |
10-02-2019, 02:38 PM | #12 |
Drives: 2017 SS 1LE Join Date: Sep 2011
I like to do my first couple runs in Track: Race and focus on learning the course and getting the tires up to temp. Once my tires are warm, it's everything off in Track mode. Everything else is too intrusive for Autox..
2017 1SS 1LE - Eibach Springs | Pray IM | Katech TB | Borla 60606 | Corsa Extreme | E85 Flex Tune
10-02-2019, 02:40 PM | #13 |
Drives: 2019 ZL1 Join Date: Aug 2018
FWIW, I run my steering in sport. Tour is just a bit too over boosted for my preference but it's just that, a preference. Try both but Sport has the advantage of slowing your hands down if you have a tendency to be too quick with them.
10-02-2019, 08:04 PM | #14 |
Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
All these people saying turn everything off....I don't think that's a good idea for your first time. Sport 1 is good to get a feel for the track. It's also great for very small tight courses. Once comfortable with that, move to Sport 2, then Race. If you still feel like you're being held back, by all means, turn everything off and try that. Just be careful if there's anything around that could cause damage if you lose control. These cars are amazing and tons of fun. You just have to see what settings work best for you.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
