07-08-2021, 03:16 PM | #99 | |
07-09-2021, 12:13 AM | #100 |
Drives: 2015 ZL1 Join Date: Feb 2020
So final revision of the quote includes:
LSA/LS3 376 CI forged block w/ oil squirters blocked off - • Diamond pistons w/ steel rings (engine shop is shooting for 10:1 to 10.5:1 ratio) • K1 H-Beam Forged Rods w/ ARP 2000 rod bolts • King Main & Rod bearings • LSA OEM crankshaft • Melling 10296 HP/HV oil pump (shop did recommend using VR1 20w50) • ARP main stud upgrade Rated for 1100hp - right around 7k out the door. And then I’ll add GPI SS3 cam. All timing components and Trunion upgrade. For about $1100 more. So $8100 total back together. Everything look good? Anything else I should add or look into getting?
787WHP/ 719TQ | Fully Forged Short Block | Custom Spec GPI Cam | DSX aux pump & FF sensor| 1200cc FIC Injectors | Lingfelter 10.0” pulley & ATI damper | RotoFab Intake | ZZ Performance solid isolator | Kooks Headers | Corsa Catback | AFCO dual fan HX | Reinforced IC brick | AEM 3-in-1 Gauge | GPI Tuned | Carbon Fiber WickerBill | Morimoto Tail-lights | WELD S71 + ET STREET R’s
07-09-2021, 08:28 AM | #101 |
I've never heard anything but good things about Thompson so if that is the way they steered you, I would follow their lead.
When you say the "shop" recommended 20w50, is that Thompson or someone else? I would get whatever Thompson recommends since their warranty probably depends on it. |
07-09-2021, 11:01 AM | #102 | |
07-10-2021, 03:15 PM | #103 |
I guess my last question is, should I keep stock compression ratio (9.1:1) or stick with engine shop recommendations of (10-10.5:1 ratio) ?
I was under the impression lower CR is best for boost. The car makes about 16lbs of boost and I run e85. What ratio should I shoot for?
07-10-2021, 10:33 PM | #104 |
Drives: zl1 blk Join Date: Nov 2017
my 416 is 10:1 im really happy with the numbers it makes.. also happy with how it sounds..
07-11-2021, 07:01 PM | #105 |
Drives: 2013 ZL1 Join Date: Mar 2013
I have a question. Why would the piston oil squirters be blocked off? To me I would think not to do that? Please educate me on this.
07-11-2021, 08:43 PM | #106 |
i'd say in most applications it adds hp .. also not really needed which im sure could be debated both ways to death . got rid of mine... also if u use a longer stroke crank it will hit the squirters.. they have shorter ones u can replace with but kind of a personal preference as well
07-13-2021, 03:00 PM | #107 | ||
07-13-2021, 03:29 PM | #108 |
So is this an LS3 block or LSA block that you are going with?
07-13-2021, 05:18 PM | #109 |
I was told straight from multiple engine shops. There is no difference in the LS3/LSA block itself. Except the oil squirters. They’re not any stronger. Only the rotating assembly is different/stronger from the factory. The LSA block is now discontinued. So instead of sourcing a LSA for $1200-2000 more than a LS3 and plugging the oil squirters. It’ll be a LS3 with a fully forged rotating assembly. Good to 1100 whp with all options I’ve selected (ARP main studs, forged pistons, rods, crank. Etc. )
07-14-2021, 07:40 AM | #110 |
Yeah, the difference between the LSA and LS3 blocks have always seemed a unclear. The "blocks" were reported as 20% stronger, but usually the description would talk about the differences in the rotating bottom end.
07-15-2021, 08:24 AM | #111 | |
Drives: 2013 ZL1 Join Date: Jan 2020
The shared issue of these being 4-bolt instead of 6-bolt is the limiting factor here, IMO. |
07-15-2021, 09:19 PM | #112 | |
Drives: '15 1LE Join Date: May 2020
