03-08-2017, 04:27 AM | #71 |
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 Join Date: Jul 2012
3.73 will work stellar at the track
03-08-2017, 05:42 AM | #72 |
I have the ZL1 hubs that I picked up as part of the purchase of my diff. I however did not install them. I don't track the car. It was hard for me to justify replacing a good part for an unknown used part. I have them for backup.
2014 L99 2SS. 595HP/571ft-lbs
Mods: LSA Conversion 2.5" Upper Pulley, 65# injectors, GPI SS1 Cam, SP Long Tubes, ADM Race Scoop & CAI, NPP exhaust (DIY control), BMR 1" lowering springs, ZL1 Rear Differential / Axles, CF Side Strip / Hood Spear, Tint - Windows / Tails / Sidemarkers, Splash Guards, ADM Boost Gauge, ABL Dashkit, '68 Script Badges, ACS T4 Splitter, ZL1 Rockers from Gary's, Z28 Spoiler, Carbon Fiber Hood Vent, Summer - MRR FS01 Satin Black (10" Front 11" Rear) Winter, pictured-Drag DR 64's Satin Black (9" Front-10" Rear.) |
03-19-2017, 09:55 PM | #73 |
Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
This thread has helped a lot with my swap. One thing I wanted to mention was that in the original post it says a 32mm socket is required to remove the SS axle nut. However, on my 2014 SS it required the same 36mm socket as the ZL1 axle nut.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
03-22-2017, 02:12 PM | #74 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Very interesting tid bit. I wrote the original post. And mine is a 2010 SS. Maybe they updated the axle end and hub in the 2014 "refresh" for the Camaro. Thanks for sharing!
03-22-2017, 03:38 PM | #75 |
You just have smaller nuts.
03-22-2017, 09:18 PM | #76 |
04-07-2017, 12:22 PM | #77 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
Whats a good source for the rear end only? what have people been paying?
04-10-2017, 05:11 PM | #78 |
Look around on ebay and here. I think Dreksnot has one he'll sell for the right deal on shipping. I did a swap with a guy for my stock diff so my price isn't really relevant. The total kit brand new can be had for $3800ish from Jegs or Summit or a few more places.
The cheapest you'll piece one together with used parts will be in the $2000-$2500ish range I think. So the kit brand new really isn't that bad of a deal. Saves you a ton of time messing around trying to find parts (some of which were backordered when I tried to get them). |
04-10-2017, 05:12 PM | #79 |
04-10-2017, 05:46 PM | #80 | |
Bring It
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold 2010 Camaro SS - 650RWHP Daily Driver - Traded |
04-11-2017, 10:23 AM | #81 |
2010 Camaro 2 SS/RS M6
Drives: 2010 Camaro SS/RS Join Date: May 2009
Quick question for you guys. If I put the Trans flange (GM part# 22960154) on my m6 SS, I can just use a regular zl1 driveshaft (from DSS) correct?
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
04-11-2017, 01:05 PM | #82 |
Yes...if you have the ZL1 trans flange (which will fit perfectly on your M6 output shaft) and the ZL1 rear end...you can then use all the ZL1 driveshafts out there (OEM or aftermarket).
Just make sure you get the driveshaft for the manual and not the auto. They are different lengths. |
04-11-2017, 02:59 PM | #83 |
Thanks for clearing that up cc rider!
04-11-2017, 03:51 PM | #84 | |
Thanks for the heavy-weight shipping info. Hopefully, will be using that on the 3.73 diff soon.
