05-17-2018, 08:26 PM | #71 |
SS Copbait R.I.
Drives: 2016 Camaro 2SS Join Date: Dec 2016
05-26-2018, 02:39 PM | #72 |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
Just replaced mine at 22,000 and it wasn't too dirty. Also, I have to say the install was a lot easier than some of you made it out to be. I was able to just compress each side of the glovebox and it popped right out.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
05-26-2018, 02:41 PM | #73 | |
05-27-2018, 07:40 AM | #74 | |
Drives: Too many to list Join Date: Dec 2011
It’s not oiled in the way that their engine air filters are oiled. It’s cleaned with a bottle of their cleaner and then sprayed with what they call “refresher” which is like a concentrated Lysol spray. K&N seems to make a point for their cabin air filters to avoid labeling them as “oiled”. Sent from my iPhone using Tapatalk Pro |
07-08-2019, 04:11 PM | #75 |
Drives: Camaro SS 1LE Join Date: Aug 2018
Resurrecting this one.
As others have mentioned, big screwdrivers or crowbars go a long way (no pun intended)and definitely tie a string to the cord. Also with the filter out, it’s a great time to spray sanitizer in the vents by the base of the hood to really get rid of odors. |
09-28-2019, 07:09 PM | #76 |
Drives: 2024 2SS Summit White Join Date: Jun 2018
I just accomplished my first cabin filter R&R and thought I'd share some observations:
As to the "considerable force" needed to disengage the plastic dowels/pegs, that all depends. Using a straight tool like a screwdriver, even a big one, really lessens the mechanical advantage. A pry bar with a small curve allows you to put the force right where you need it...adjacent to the dowel. In this way, not a whole lot of force required. You can also use the box end of a large-ish ( 7/8'' to 1" ) combo wrench, as the box end is angled upward. Trying to use a flat screwdriver means applying lots of force along the whole side of the glove box: I could see where some would be concerned they'll break the thing. I know I was. Attaching "pull" wire or whatever to the lanyard was a GREAT idea. Thanks. Did the whole thing in 10 or 12 minutes. I can shave that down to 5 or so next time. |
10-01-2019, 09:51 AM | #77 |
Drives: 2018 SS 1LE Join Date: Apr 2016
Just did mine as well. No issue and yeah it takes some effort to overcome the dowels.
I snapped my little bungee string, I had it attached and moved out of the way but when I went to pull it back down I pulled it down to far and snapped. Oh well its a glove box.. I looked at the replacing it but that thing is far up there. Not worth the hassle.. Sucks.. but oh well... |
12-21-2019, 08:26 PM | #78 | |
Drives: 2017 Camaro SS Fifty Join Date: Oct 2016
I went to order this filter from Amazon and it says "Does Not Fit You Vehicle" but Ebay says it does but Ebay is $10.00 more? |
04-23-2020, 09:00 AM | #79 |
Drives: Chevrolet Camaro Join Date: Oct 2019
This might be dumb. Was there a switch or process to tell the car PCM that the filter is changed. Allegedly, Onstar called my Chevy dealer to say the filter was due (mileage I am sure). I want to make sure Onstar STFU about the filter once done.
04-30-2020, 12:31 AM | #80 |
Drives: 2017 2SS M6 Join Date: Jun 2013
found mine filled with a mouse nest.
04-30-2020, 12:32 AM | #81 |
no there just recommending it because of mileage or time. they have no idea if it really needs to be or if its been changed.
04-30-2020, 12:34 AM | #82 | |
05-08-2020, 10:27 PM | #83 |
Drives: blue velvet Join Date: Jul 2018
just took me nearly an hour to do. never had such a hard time in any other car, but i'm glad it's done. car has 22,000 miles, and the filter was filthy.
12-20-2021, 01:52 PM | #84 | |
Drives: 2017 1SS 6spd Join Date: Jan 2011
one of our vendors and got a cabin filter for a Dodge Ram!? BTW- you're right you should've got a ZL1. All the work you've done reminds of all the effort I put in my 2010 RS (including S/C'ing). But it was alot of fun though, huh? |
