TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Photos | Spyshots | Video | Media Gallery
Old 03-21-2009, 07:28 PM   #57
Hillbilly
Rider of the short BUS
Hillbilly's Avatar
Drives: Ukon/F350(work)/Intruder800
http://www.woodyg.com/fairlane/finfo/etrwh.html
http://www.race-cars.net/calculators/et_calculator.html
Here is a couple links to play with.
SIM with CGM rallieshttp://www.creativegraphicsvinyldesign.com/images/SIM1.jpg
Hillbilly is offline   Reply With Quote
Old 03-21-2009, 07:32 PM   #58
Hillbilly
Hillbilly's Avatar
Originally Posted by Krobar View Post
I dont think they are bad at all for stock #'s. The SRT8 got 356 RWHP stock so we are ahead of the game there. http://www.dragtimes.com/Dodge-Chall...lip-15527.html
Yep
And with the extra weight I read a review (SRT 13.9/Camaro13.0)Way ahead now
Old 03-21-2009, 07:52 PM   #59
1fastdog
Drives: 2002 Z06
Originally Posted by silverc5vert View Post
The engine was at normal operating temperature (coolant temp around 220), SAE correction factor, 1,000 miles, traction control has to be off to run on the dyno, 93 octane fuel, and a/f wasn't logged, we were just doing power pulls.
-Rick
Thanks!
I don't see an issue with the numbers. Did you mention the dyno is a bit conservative with readings? If so, that is better as a tuning tool. Generous dynos are something I avoid.
I tend to believe that between 13% and 14% is a closer number for a loss factor. Multiplying the flywheel by .86 or .87 is my personal rule of thumb for an IRS RWD car with a manual tranny. By no means a hard and fast rule, as drivetrain losses can vary due to a number of factors, even between same model vehicles.
A plus of minus 5 HP isn't considered out of the question from a dyno pass.
Low mile engine and trans, stingy dyno, 5HP error factor....
I can't see why folks are anxious over this dyno pass.
Without an AFR, IAT, and knock retard readings? More reason to not be worked up.
1fastdog
many Z/28's in my past
1fastdog is offline   Reply With Quote
Old 03-21-2009, 07:55 PM   #60
Q8-CamaroSS
Muscle Owner
Q8-CamaroSS's Avatar
Drives: 04 Chevy SSR/03 RST/82 Fj40
Send a message via MSN to Q8-CamaroSS
Camaro is the New Drag Race Muscle Car end of discussion ..!!! Just Imagine a Camaro with 16 inch Rear's with Sticky tires Umm Mean Machine !!
Chevrolet SSR '04
[IMG]http://i52.photobucket.com/albums/g30/MadBoy_BadBoy/DS****21_2.jpg[/IMG]
Fesler Moss Camaro 2010 LSX Supercharged Mid Loaded..
Q8-CamaroSS is offline   Reply With Quote
Old 03-21-2009, 08:56 PM   #61
tom692010
Drives: 4 wheels
so where is the 425 hp
I know every cars a bit different but this is no where near the 425 the are advertising. With a little work though once mine arrives I'm sure it will get there. Now let them dyno the Challenger which is supposed to be 425 also and see what it gets.
Still wouldn't change my mind 1ss iom in 2mo!
tom692010 is offline   Reply With Quote
Old 03-21-2009, 08:59 PM   #62
z28xtreme
Drives: #17 Pontiac G8 GT
Originally Posted by Muscle Master View Post
Compared to the SRT8, again maybe it's the gearing
What is the gearing for the manual SS anyway, The SRT8 gearing is 3.92 axle ratio with 20 inch rims
The R/T is 3.73 with 18 inch Rims
gearing has nothing to do with the horsepower. hp is hp plain and simple. the rims dont either.
z28xtreme is offline   Reply With Quote
Old 03-21-2009, 09:08 PM   #63
UCF w00t
Geek
UCF w00t's Avatar
Drives: IOM 2010 Camaro 2SS
The 426HP advertised is straight off the engine... not at the wheels. This is normal.
And the challenger has been dynoed...
UCF w00t is offline   Reply With Quote
Old 03-21-2009, 09:26 PM   #64
Chocolate Apocalypse
Full Fledged Member
Chocolate Apocalypse's Avatar
Drives: '18 1SS 1LE
Actually they do. If you take a 4th gen w/3.42s, dyno it, swap in 4:10s, dyno it, you'll end up with a few less ponies running the 4:10s. Also, the weight of a tire/wheel combo makes a difference. Bigger/heavier combo will result in lower numbers on the dyno vs a smaller/lighter combination.
'18 1SS 1LE - DD
'72 Cutlass - LSA topped 370" LS2
Chocolate Apocalypse is offline   Reply With Quote
Old 03-21-2009, 11:07 PM   #65
gunslinger
Drives: 1998 Z28 M6
Probably the biggest difference between the Vette and Camaro RWHP numbers is in the IRS design.
From what I remember reading, the Vette has a more efficient IRS design, allowing more HP to make it to the ground. (It also probably had less rotating mass because it doesnt have to accelerate a car weighing ~4000 Lbs.).
So my guess is tuning and exhaust make up about 5 RWHP and the IRS makes up the other 5-7 RWHP on the Vette.
GTR: Get Transmission Replaced
gunslinger is offline   Reply With Quote
Old 03-21-2009, 11:15 PM   #66
gunslinger
Drives: 1998 Z28 M6
The gears actually do not make any difference, it is just that the 4.10's are less efficient, meaning the actual ratio makes no difference. The heavier wheels do make a difference because they are a rotating mass connected to the engine and the less mass the engine has to accelerate, the higher the HP.
The way the dyno calculates HP is by accelerating a known weight and the speed of acceleration of that weight determines the HP. So gears have no effect on the HP reading because gears only multiply torque, not HP.
Old 03-21-2009, 11:23 PM   #67
G8GT4now
G8GT4now's Avatar
Drives: 14 SS Sedan
Livernois dynoed a GXP with very very low miles on it (17 miles I think) and it put down 350ish hp, the same car 1000 miles later put down 370ish. Both videos are in this thread.
After a catback, roto fab intake, and tuning, that GXP now puts down 410ish RWHP.
http://forum.grrrr8.net/showthread.php?t=4830
G8GT4now is offline   Reply With Quote
Old 03-22-2009, 12:47 AM   #68
65535
Mopar or No Car till 2010
65535's Avatar
Drives: Dodge Charger SE 3.5
Due to the fact that the car is stationary on the dyno, inertia is zero.. So curb weight makes no difference whatsoever in recorded hp numbers
65535 is offline   Reply With Quote
Old 03-22-2009, 01:07 AM   #69
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Originally Posted by Hillbilly View Post
AS an old drag racer I see the numbers on the reviews and something looks a bit off.
The 1/4 time seems a little slow for the trap speed show. 111 MPH trap speed. I would think with a great lauch the car should run low 12.90's.
Also with a trap speed of 111 I would think the rear wheel horse power would be more like 380
Just my thoughts from watch a bunch of timed runs over the years.
Winter test makes for poor grip and very dense air, so slow launch and high trap.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 03-22-2009, 07:08 AM   #70
JJ#48Racing
Drives: 1998 Camaro SS
3.45 for the camaro SS M6
The mags don't test on an actual drag strip. They use a section of road or straight section of road course. Thus the higher e.t. usually.
364rwhp is just over 14% loss from 426fwhp. These numbers are spot on especially considering the car only had 1,000 miles on it.
Gearing has nothing to do with fwhp, but it does affect rwhp. Numerically larger gears require more energy to turn resulting in more drivetrain loss and lower dyno numbers. But on the street the extra leverage from the gears makes the car quicker. Big wheels usually result in more weight which also cause more drivetrain loss and lower rwhp.
HP is a multiplication of TQ, so if TQ is multiplied by gears, then the gears indirectly affect HP. Fwhp is not affected by gears, but rwhp is.
He was refering to the weight of the dyno drum, not the car's weight.
JJ#48Racing is offline   Reply With Quote
Camaro Product Manager - interview Moose 5th Gen Camaro SS LS LT General Discussions 11 04-04-2012 06:10 PM
GM memo to dealers Moose 5th Gen Camaro SS LS LT General Discussions 41 02-04-2010 07:33 PM
Official Camaro Convertible CONCEPT Press Release Tran Camaro Convertible Forum 12 11-18-2009 07:05 PM
Comparison Test, by Proxy: 2010 Chevrolet Camaro vs. 2009 Dodge Challenger SRT8 AirGoya Chevy Camaro vs... 86 07-24-2008 11:20 AM
Camaro (concept) Press Release!! Pencil.Fight 5th Gen Camaro SS LS LT General Discussions 4 07-21-2008 03:33 PM
