dave@hennessey
Old 07-10-2020, 11:56 AM   #57
johnnyb305mia
Drives: 2015 Camaro SS 1LE
Originally Posted by Rose_Maro View Post
Are you still spraying on this set up? Or just turbo now?
I have nitrous as well. I just don’t have it hooked up right now. But we do have gap insurance.
johnnyb305mia is offline   Reply With Quote
Old 07-10-2020, 04:09 PM   #58
Rose_Maro
GL 2814
Rose_Maro's Avatar
Drives: 2010 Camaro SS
my man!
Rose_Maro is offline   Reply With Quote
Old 07-21-2020, 02:20 PM   #59
johnnyb305mia
Update a little over a week ago we went back to the dyno. I swapped the injectors. And we turned it up. It was good to be able to not reach any limits other than the SBE, and leaving it where it is for now to enjoy it for a bit. Makes 9xx on 16psi. Def has more in it, but like I said we left it there for now. Gotta start dialing it in, and testing it out. But it feels good. Just replaced my battery too with a DieHard AGM Battery. OEM AcDelco battery was still going, but getting low with a hard crank on hot start, ever since new battery swap no longer an issue.
Old 07-21-2020, 07:05 PM   #60
joshnmn
2&THEHIT
joshnmn's Avatar
Nice!
Old 07-23-2020, 02:47 PM   #61
Rose_Maro
GL 2814
Rose_Maro's Avatar
If you haven't already, throw an extra ground on the driver side from block to body. Will help with hot start cranks TREMENDOUSLY.
Old 07-23-2020, 03:48 PM   #62
johnnyb305mia
I have not, nor do I have the issue. The battery got low and it did that. But I’ve tossed the idea of replacing all of the grounds on the car to better handle the extra accesories the car runs.
Old 07-24-2020, 11:57 AM   #63
Rose_Maro
GL 2814
Rose_Maro's Avatar
Its an easy add on and helps with our cars a lot.
Your build is sick man. Enjoy it.
Old 08-08-2020, 05:15 PM   #64
AGM 1LE
AGM 1LE's Avatar
Drives: 14 SS/ 1LE
How is the new return style fuel system with the external pusher pump working for you? And where did you route the return line to at the tank?
2014 1SS/1LE
AGP 57/57s, E85 + meth injection, Monster triple, ZL1 diff swap, Z28 coilovers
AGM 1LE is offline   Reply With Quote
Old 08-28-2020, 02:15 PM   #65
johnnyb305mia
Works great no issues. It's not routed back to the tank. It routed back into the custom aux system I made. It taps in via a Tee behind the AUX pump. so when not circulated back through the aux system aka normal driving, it bleeds off into the tank that way
Old 08-29-2020, 04:26 PM   #66
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
Nice....
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 09-03-2020, 04:55 PM   #67
SS Performance
SS Performance's Avatar
Drives: 02 Camaro B4C
Interested in info on what hood you went with. Pictures?
A man's garage is his castle
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2014 Camaro SS Dedicated Track Car
2015 Camaro 1SS 1LE
2008 HHR SS
1996 Silverado Crew Cab Long Bed Dual Rear Wheel
SS Performance is offline   Reply With Quote
Old 09-04-2020, 06:34 PM   #68
johnnyb305mia
Another OEM hood I used
Old 09-05-2020, 12:51 PM   #69
SS Performance
Does it clear the intake or did you modify it?
Thanks
Craig
1969 Camaro SS
1970 Camaro SS
2002 Camaro B4C
2015 Camaro 1SS 1LE
2008 HHR SS
Old 09-07-2020, 02:34 PM   #70
johnnyb305mia
Thanks
Craig
You need to cut it
