02-03-2014, 08:12 PM | #281 |
Drives: 2010 IOM SS Join Date: Aug 2009
Its only 2 fillups for you to Texas. I say go for it. You'll have lots of alone time or maybe Murray will go and your let him touch it
02-03-2014, 08:15 PM | #282 |
Drives: 2010 Camaro Join Date: Feb 2010
Driving a car is a piece of cake. Dragging a 48' trailer pretty much sucks balls. I'll think about it. I do need redemption from last years debocle.
02-03-2014, 08:22 PM | #283 |
Make your peace with God!
Drives: 2011 Camaro SS/RS M6 Convertible Join Date: Dec 2011
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ UNDER MAJOR OVERHAUL!! |
02-03-2014, 08:24 PM | #284 |
02-03-2014, 08:26 PM | #285 |
Yea, but you were smart enough to give them to him, and your motor didn't blow twice because of the same issue.
02-03-2014, 08:27 PM | #286 | |
CamaroFans.com
02-03-2014, 09:47 PM | #287 |
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Solid before full break in.
02-04-2014, 05:21 AM | #288 |
Drives: 1999 Trans Am Join Date: Jul 2009
Can't really compare this converter/ th400 to much. Can tell by the torque that the hp numbers are way off compared to a locked up setup.
Test is to see how it goes down the track. |
02-04-2014, 07:17 AM | #289 |
instigator
Drives: 2020 6.2 Trail Boss, 2022 XC90 Join Date: Jan 2010
I know this is a 3 speed but you guys are evil because you got my wheels turning about a built 4L80 dropping my current ET. dang you yankees.
-John S.
02-04-2014, 08:19 AM | #290 | |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
just want to poke the bear a little. |
02-04-2014, 10:21 AM | #291 |
Thats an easy Drive... trailer and all..... Please....
Ive done from here to Mt Rushmore Non stop.. Gas ... with a 20 ft trailer filled with motorcycles...... NON STOP..... |
02-04-2014, 10:42 AM | #292 |
20', 5k lbs trailer is worlds apart from 48', 20k lbs. I'll buy you lunch if you can get it out of the parking lot.
02-04-2014, 12:11 PM | #293 |
Both Matt and Don said it would be the best trans to get the most out of the car on the track. I would have gone with whatever they wanted.
02-04-2014, 03:12 PM | #294 |
Drives: 2013 TT ZL1 Join Date: Jun 2013
How many of you guys are going to Camarofest? Its a 24 hour haul for me with a trailer, I've been planning on it but I want to make sure all the cool kids are gonna be there also.
