Old 03-30-2015, 09:00 AM   #15
JaxChris
Drives: '16 2SS GD1 MX0 NPP F55 IO6
Originally Posted by Bhobbs View Post
I hope this means the curb weight will be 200 lbs less and not like the Mustang where the chassis was lighter but the finished car ended up heavier.
The PR post specifically says "reduce total curb weight for the new Camaro by more than 200 pounds". My curiosity is whether they are referring to each variant from 2015 to 2016 or if only the top model or bottom model has shaved over 200 lbs. Those with the composite suspension members will have the most weight savings, but those probably only come with the heavier/stiffer pistons on the performance variants to keep them highly competitive on paper.
Personal note 1: Looks like the center console will be going to a more traditional affair with a normal center stack in the dash. I think this is a good thing. I'm looking forward to something more ergonomic and easier to customize.
Personal note 2: My fear that Gen6 is going to end up looking like a Scion FR-S competitor have not yet been quelled. I hope it has all been epic misdirect with the front clip, hood and those lights. "Body by Veilside, lights by APC, bred for the '95 Eclipse, now available in American RWD"? ;o(
JaxChris is offline   Reply With Quote
Old 03-30-2015, 09:01 AM   #16
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
I'll have to check the door sticker again but I tbink the 2015 1LE has a curb weight of over 3900 lbs.
1SS base is 3908lbs. Figure a bit more than that but then drop 200lbs (or more as GM states "at least") that would be 3708lbs for a base SS.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 03-30-2015, 09:02 AM   #17
All good points.
Old 03-30-2015, 09:15 AM   #18
Autonaut
Drives: El camino
This is fantastic news. Well done GM. Im really looking foreward to the actual reveal.
Autonaut is offline   Reply With Quote
Old 03-30-2015, 09:16 AM   #19
87GNX
87GNX's Avatar
Drives: Alot
I wont believe it, till it's weighed!
IF YOU AIN'T FIRST, YOU'RE LAST
87GNX is offline   Reply With Quote
Old 03-30-2015, 09:33 AM   #20
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
The components they have showed as examples of weight reduction would be found on all models. So with that I would say it's safe to say the base models will see that 200lb loss. Performance models may see more, but could be offset by beefier components.
FR-S as a competitor? You are joking right?
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3
"Voices in your head are not considered insider information."
3800 Status - 6/16/16 (Built!)
6000 status - 6/29/16 (Delivered!)
SuperSound is offline   Reply With Quote
Old 03-30-2015, 09:40 AM   #21
3Black
Drives: 2014 1SS/RS M6
God i love the words "at least".
3Black is offline   Reply With Quote
Old 03-30-2015, 09:53 AM   #22
Camaro_Corvette
36.58625, -121.7568
Camaro_Corvette's Avatar
Drives: Team 1LE
2015 1LE curb weight is 3875lbs. I can't remember but I think the 2013's were even lighter.
Old 03-30-2015, 09:54 AM   #23
NAS
NAS's Avatar
Drives: '10 SS
Man I can't wait to see the unveiling of the 6th gen. I can't believe it's already been 6 years the 5th gen has been out wow time flies.
NAS is offline   Reply With Quote
Old 03-30-2015, 09:59 AM   #24
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
GM has stated 3875 and 3860.
Old 03-30-2015, 10:00 AM   #25
LesserO2Evils
GM repeat offender...
Drives: 16 2SS
3700lbs w/460 or so HP will be a gamechanger.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15
INCOMING: ‘22 ZL1, Satin Steel. A10. PDR.
Ordered: 03/02/22.
LesserO2Evils is offline   Reply With Quote
Old 03-30-2015, 10:04 AM   #26
Camaro_Corvette
36.58625, -121.7568
Drives: Team 1LE
And there it is, thanks!
Old 03-30-2015, 10:04 AM   #27
Jbryant910
Drives: 2014 Malibu
If the 6th gen is a total of 200lbs less, that would be the equivalent to a 20 hp increase correct? So the acceleration and speed should be like a 480 hp 5th gen? That's assuming if the LT1 comes with 460 hp for the camaro.
Jbryant910 is offline   Reply With Quote
Old 03-30-2015, 10:15 AM   #28
Autonaut
Drives: El camino
So will 3650
"At least 200 pounds"
3650 1le will destroy all cars within it's price range. It will take a gt350 to out run it.
Good times ahead.
Some minor weight mods will put it at 3600 easily!!
2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 camaro pounds, 2016 camaro spy, 2016 camaro spy photo, 2016 camaro spy photos, 2016 camaro spy pics, 2016 camaro weighs, 2016 camaro weight, 2016 chevrolet camaro, 2016 chevy camaro, 2016 chevy camaro pounds, 2016 chevy camaro weight, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen camaro weight, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
