Vararam
Old 12-23-2016, 09:29 AM   #15
Arthur Collins
Police Magnet No more V6
Arthur Collins's Avatar
Drives: 2011 Camaro 1LT/RS To 2017 50th 2SS
Send a message via Yahoo to Arthur Collins
it lives and no check engine light.
Arthur Collins is offline   Reply With Quote
Old 12-23-2016, 09:33 AM   #16
djrasras
djrasras's Avatar
Drives: 2010 2LT Bumblebee
Congrats bro! Sounds like you just saved yourself a ton of money
AirLift Air Suspension, Stainless Works Long Tube Headers + Hi-Flo Cats, Resonated X-Pipe, MRT V2 Mufflers, VMAX Ice-olator and Ported Throttle Body, Barton Short Throw Shifter, CAI Intake + Air Scoop
djrasras is offline   Reply With Quote
Old 12-23-2016, 09:35 AM   #17
Arthur Collins
I suck at posting videos
[u2b]
[u2b]
Old 12-23-2016, 10:19 AM   #18
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Congrats, what all did you end up having to replace?
Old 12-23-2016, 08:12 PM   #19
Arthur Collins
I had to pull the motor because I couldn't drop the subframe in my driveway that took a while. The mechanic that worked on it forgot to include most of the nuts for my headers so I went to homedepo. I replaced all 6 rod bearings and took the crank to my friends garage, it turned out that the old bearing had left a layer of aluminum on the crank so we hit it with muriatic acid. the acid left a very clean crank but left minor scratches so we ended up polishing the crank with 2k grit and it was good as new. Replaced front cover gasket and did its last oil change. The oil filter saved my motor. We did use a micrometer and plastigauge too
Old 12-24-2016, 04:53 AM   #20
Arthur Collins
Originally Posted by Soybeanrice View Post
Cool to see youre having "fun" with your car. I'll be doing a timing chain on an LY7 next week.
How did you get the oil pan off with the engine in the car? Isnt the cross member in the way?
Took out the engine because I couldnt drop the subframe
Old 01-03-2017, 02:14 PM   #21
BenzinaBrera
BenzinaBrera's Avatar
Drives: Alfa Romeo Brera V6
but what caused the failure in the first place? you dont want this to happen again im sure.... had oil pump failure on 2 of those engines so far in South Africa, also the bearing tolerances are hyper sensitive, technically the bearings has to be guaged to check if the tolerance is in spec with the new bearings, last bearing i replaced would have died again if i didnt check the tolerance...
[/URL]
Alfa Romeo- Only passions, great passions can elevate the soul to great things
BenzinaBrera is offline   Reply With Quote
Old 01-03-2017, 09:43 PM   #22
Zezima
Zezima's Avatar
Drives: 2014 Camaro 2LT/RS
LOL I was gonna part it out but its gone now
you could of made serious cash on the halos, wheels and seat covers, serious cash
Zezima is offline   Reply With Quote
Old 01-04-2017, 04:38 AM   #23
Arthur Collins
From what i'm guessing, the front engine cover was leaking pretty bad and the rod bearing didn't have enough oil between my crank and bearing. The rod bearing tangs were destroyed and it spun with my crank until the bearings got sandwiched together and it seized to the crank. Oddly I didn't find any metal in the oil pump. The plastigauge clearances that I went with were (0.0007 - 0.0010)IN I also used CB-1877 A(6) standard bearings. The main bearing clearance was spot on 0.0006IN they looked brand new so I reused them.
Old 01-04-2017, 04:43 AM   #24
Arthur Collins
lol I could have had a TT build and made some moolah!
blown engine, dealer, rod knock
