06-09-2019, 06:42 AM | #15 |
Drives: 2017 Camaro 1SS Join Date: Aug 2016
Found that the metal cap works alright if you note the orientation, it seems to seal better in a certain orientation, weird but that's what member Stephen12ZL1 had said and that seemed to work out. Mark the cap with a sharpie when you find it's sweet spot.
I used it only for pressure, did not put any fluid in it. Therefore no mess. With the cap orientation sorted out, not a problem to depressurize, top off the fluid, reinstall, pump back up, and move some more fluid. Last edited by wnta1ss; 06-09-2019 at 07:01 AM. Reason: fix name |
06-09-2019, 06:56 AM | #16 |
you can purge quite a bit from our master cylinder reservoir before you need to depressurize and refill. Start with the master cylinder filled as much as will fit. Once you are confident the level isn't dropping too low, this procedure goes very smoothly.
06-09-2019, 06:53 PM | #17 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
I don't have anything more to offer the OP that hasn't been said, and it is unfortunate the end result is to return the unit because it's quite useful. I myself have had great luck with mine and use it often!!! I too use it dry, and fill the master cylinder, and have had no drop in pressure by leakage in the 10-20psi range. I even tend to go overboard and re-pressurize to starting pressure with each bleeder (twice per caliper). I rely too much on my brakes to slow/stop my crazy a$$ on track. Have not had the opportunity to try a vacuum bleeder as of yet to compare.
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
06-11-2019, 10:15 AM | #18 | |
Drives: 18' 1SS 1LE HyperBlue Join Date: Sep 2018
So i've never done this before. We made the attempt last night and spent hours trying to chase air out of the system. I ended up taking it to my neighborhood garage - no matter what we did there was way too much sponge happening - and that's no good on a strip or a track. Could someone in painful detail give me the English version of how to do a brake fluid swap on my SS 1LE? Youtube videos do too many super cuts where they don't show the whole process. The last thread I saw here about it was incredibly vague. (It didn't even mention the fact there are two bleeder valves (inner and outer) on each of our brakes.) So that was the wrong place for me to be reading a how to. I bought the GM manual (275$) - nothings listed in there in any kind of order, so sorting through which procedure was the one I was looking for was like deciphering hieroglyphics. It's a great book - but only if you know exactly what you're doing already. |
06-11-2019, 03:54 PM | #19 |
Drives: BMW M3, ZL1 1LE Join Date: Mar 2019
This is what I do ever since I had a hose burst and send brake fluid in my eye. I just keep an eye on the fluid level in the reservoir and refill it after I hit each caliper. It takes more time to bleed but saves time cleaning up the hoses when you are done.
06-11-2019, 03:56 PM | #20 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
ouch! i was worried about the paint, but the eye sounds worse
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
06-13-2019, 12:03 PM | #21 | |
Drives: 2018 1SS 1LE HBM Join Date: Jul 2014
06-13-2019, 12:13 PM | #22 |
Check out the post by Destroyer 1LE on page 6 of the brake section. He has a pretty good write up verdicaysen. Not sure about the clutch part as I've never done that and didn't do it when doing my Camaro either. Did it the old fashioned way with a helper applying brake pressure.
06-13-2019, 04:23 PM | #23 | |
03-17-2024, 09:17 AM | #24 |
Drives: 2021 Camaro LT1 Join Date: Oct 2023
I've used vacuum bleeders in the past, and for me the Motul has always worked a lot better. I always fill it with brake fluid and I've been really happy with how quickly I can bleed a lot of fluid through and get clean fluid throughout the system. I have spilled before, but I just wipe it up - I haven't really had any big issues.
I haven't used it on the Camaro yet. Thanks to everyone for the helpful posts and tips. |
