03-23-2020, 06:28 PM | #15 |
Drives: Chevrolet camaro ss Join Date: Mar 2020
Check fuel line connctors under the abs module do not crank just turn the ignition key to build up pressure then check them wet or dry if wet may be a cracked hose or faulty fitting seal
03-24-2020, 12:56 PM | #16 |
Drives: 2013 Camaro LFX 2LT Join Date: Mar 2020
Thank you, everyone, for pitching your ideas as to what could be wrong.
All injectors are working fine but there is an apparent leak in the injector O rings, leaking O rings are being replaced today and the car will be tested to confirm all is well now. I'll post back to confirm the diagnostic and if it has been fixed. |
03-25-2020, 01:17 PM | #17 |
So it was just a leak from the upper intake manifold seals, they replaced the seal and she's back home alive and well.
Luckily it was just that and not something more expensive () as I had just spent quite some money on 6 brand new injectors and mechanic's bill Sincerely, thank you all for your help! |
03-25-2020, 02:15 PM | #18 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
congrats!
03-26-2020, 06:52 PM | #19 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
Glad you got it solved and that it was an easy (relatively) fix!
fuel injection, fuel pressure, gas smell, injectors, rough engine |
