Roto-Fab
Old 04-30-2024, 04:00 PM   #15
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
Originally Posted by gtstorey View Post
Mouse330 is offline   Reply With Quote
Old 04-30-2024, 04:10 PM   #16
gtstorey
Originally Posted by Cali_Camaro_SS View Post
I also would think if it’s the fuse then all odd coils would be dead?
Originally Posted by Mouse330 View Post
All odd coils are fed by fuse 10 so the fuse should be good or the whole bank would be dead
You already answered this question.
Old 05-08-2024, 10:40 PM   #17
Cali_Camaro_SS
Cali_Camaro_SS's Avatar
Drives: 2010 Camaro 1SS (BLACK)
Quick update: tested the connector and it has power on the pink wire. Pulled the plug and doesn’t appear to have any cracks no oil. Checked the plug wire and seem clean no corrosion on the metal. Checked the wire with the multimeter also and shows .8 ohms set it to 20k is that too low?
Cali_Camaro_SS is offline   Reply With Quote
Old 05-09-2024, 08:01 AM   #18
gtstorey
If you are still chasing the code for #7 coil, just swap the coil to another cylinder and see if the code follows.
Old 05-09-2024, 01:40 PM   #19
Cali_Camaro_SS
Switched the new coil with another and it did not follow. So of course my luck it’s not the coil.
Old 05-09-2024, 02:03 PM   #20
gtstorey
Have you tried looking up the OEM Service manual diagnostic steps for your code? Free internet stuff and forums can only get you so far.
Old 05-09-2024, 02:44 PM   #21
Cali_Camaro_SS
I have not done that yet, I will look into that as well thank you.
Old 05-18-2024, 10:59 AM   #22
Cali_Camaro_SS
Quick question to rule out some stuff
Can the tune from Diablo tuner possibly cause this? If it corrupted somehow
Also I have a leak from the gas tank, I think from the seal.
Can one of those cause a misfire?
