Vararam
Old 12-15-2013, 07:07 PM   #15
the barber
the barber's Avatar
Drives: 13' Sw 2ss Ls3
The squirt marks u see when the window fogs is likely something u used on the dash such as a armorall and got onto the windshield which should b cleaned immediately, as far for exterior when seasons start changing I use plenty soap and water sprayed on the windshield then use several new razor blades to clean any thing off it such as tree sap
the barber is offline   Reply With Quote
Old 12-16-2013, 09:26 AM   #16
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
Originally Posted by CamaroDreams07 View Post
Any automotive window cleaner. I use megs d120 because it's super cheap. Don't get fooled by the big bucks window cleaners.
Huge fan of D120! Use it around the house as well!
Todd@Autopia is offline   Reply With Quote
Old 12-17-2013, 07:21 PM   #17
63roni
A63roni
Drives: 2014 Camaro 1Lt
Originally Posted by Bucci View Post
Use isopropyl alcohol.
It with lift off the contaminates to the surface and allow you to wipe away.
How do you apply your alcohol? Thanks!
63roni is offline   Reply With Quote
Old 12-17-2013, 07:24 PM   #18
63roni
A63roni
Originally Posted by Camarodriver2 View Post
I've heard straight white vinegar and newspaper.
Tried newspaper, will try with vinegar. Thanks!
Old 12-17-2013, 07:28 PM   #19
63roni
A63roni
Originally Posted by el ess A View Post
I've used this with great results. Kinda cheap, but very tough (can't tear it), washable and only uses water! But it needs to be barely damp. No streaking if you do it right.
http://www.ultimatecloth.com/
Finding the right cloth or whatever that will not leave materiel behind is half of my problem, Thanks!
Old 12-17-2013, 07:31 PM   #20
63roni
A63roni
Originally Posted by JTruckenbrod View Post
Be weary as to what you use on the inside of your windows if you have tinting.
Also bookmark this: http://www.camaro5.com/forums/showthread.php?t=275418
No tint, Thanks!
Old 12-17-2013, 07:33 PM   #21
63roni
A63roni
Originally Posted by otter View Post
I use Invisible Glass and micro fiber clothes.
I think a lot of it is technique. I spray the product on the cloth and go over the window twice. The first time going across and then up and down. This way I am sure I don't miss an area.
I do this on both the inside and outside.
I have that technique down, Thanks!
Old 12-17-2013, 07:36 PM   #22
63roni
A63roni
Clay the outsides as well before cleaning. Glass needs claying quite frequently
Sent from my HTC One using Tapatalk 2
Never heard of claying, will have to look that up! Although my main concern is the inside. Thanks!
Old 12-17-2013, 07:40 PM   #23
63roni
A63roni
Originally Posted by trashmanssd View Post
you can also use (0000) steal wool with window cleaner on the outside especially the windshield takes all the contaminants off and smooths edges on any pitting on windshiled
Will keep that in mind as my windshield ages, my problem is the inside. Thanks!
Old 12-17-2013, 07:43 PM   #24
63roni
A63roni
Originally Posted by 04goatgirl View Post
Invisible glass by Stoners You can buy at most auto parts store and walmart. Its safe for tint
Second recommendation for Invisible Glass. That's what I am looking for, the most repeated recommendations. Thanks!
Old 12-17-2013, 07:45 PM   #25
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Fascinating.
[B]
CamaroDreams07 is offline   Reply With Quote
Old 12-17-2013, 07:47 PM   #26
63roni
A63roni
Originally Posted by jshaf View Post
I agree with both alcohol on the outside and vineger on the inside, once clean I use stoners both inside and out. usually use a glass sealant in the spring for the summer driving season
Ok, for the "inside" Vinegar then Stoners Invisible Glass? Thanks!
Old 12-17-2013, 07:48 PM   #27
CamaroDreams07
Drives: Slow V6
9 posts in a row. Multi quote would have worked well
[B]
Old 12-17-2013, 07:49 PM   #28
63roni
A63roni
Originally Posted by flyinlow89 View Post
Ammonia is what you want to avoid. Winded has ammonia which will harm tint. Just read the bottle. I use stoner invisible glass. Cheap and over-the-counter
Another recommendation for Stoners, Thanks!
