04-25-2023, 12:34 PM | #15 | |
Drives: Black 2017 Camaro SS 1LE Join Date: Dec 2016
Looks like I might have to pull off the Whipple to get to the oil pressure sensor one and was going to see what else is needed depending on the location of the oil pump wire.
2017 1LE SS Black - Mods - Forged - lowered compression - BTR custom Cam - Whipple, 3.500 upper and 8.0 lower pulley, Roto-Fab, 1 7/8 Kooks headers, off road pipes, & 3" Kooks full exhaust. LT4 fuel system, with Alky single nozzle running 100% meth. (not installed yet) DSX Tuning flex fuel and DSX tuning Aux pump
04-25-2023, 01:31 PM | #16 | |
There is wiring to the oil pressure sensor. Damage to that probably will cause a DTC and no reading on the pressure gauge. Wiring to the pump is to the pressure control solenoid. The pump defaults to high pressure (i.e. when there is no power). In certain situations, the low pressure mode will be energized, but I do not believe this is the case for idle. there is no wiring to the pressure relief valve. This is the standard "dumb" type of relief valve which opens when oil pressure exceeds a certain amount, entirely controlled by a spring pushing on the valve. |
04-25-2023, 03:15 PM | #17 | |
Drives: 2017 Bright Yellow ZL1 6spd Join Date: May 2010
At WOT, I get over 80#. Not so sure this is good.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
