08-11-2017, 12:03 PM | #393 | |||
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
On the 15x10 rear I will go with M/T ET Street R's - 325/50/15 as previously stated which is a 28.3" tire. On the 17x8 front I will go with a Pirelli Scorpion Zero Asimmetrico - 255/55/17 which is a 28.3" tire. Looks like a perfect match!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
08-11-2017, 02:31 PM | #394 |
Drives: Twin turbo G8 GXP Join Date: Dec 2012
Scorpion is a truck tire.
9.88 @ 144
https://youtu.be/nN0rz1RAcJw |
08-11-2017, 03:22 PM | #395 |
Drives: 2011 2SS/RS LS3 Join Date: Apr 2017
Truck tires on a track car. Sweet!
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
08-11-2017, 04:33 PM | #396 |
Back to the drawing board. I didn't care if it was a tank tire so long as it fit, was light, and had a decent speed rating , but my son works at Discount Tire and they could only find one of them. Not too easy finding a 28" tire to fit a 17x8 rim. I found some run flats that were 27.6" which would be ok but they weighed like 36 lbs each,
08-11-2017, 06:31 PM | #397 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
I drive around on 28x4.50/17 m&h racemaster bias ply fronts no problem. I mean dont take a sharp turn at 70 and you'll b ok.
08-11-2017, 09:55 PM | #398 |
I am beginning to consider the skinnies if I can change my order. I am just not coming up with much to choose from for a 17x8 rim in a 28" tire.
08-12-2017, 12:29 AM | #399 |
Drives: 2005 silverado ss 2010 camaro ss Join Date: Feb 2011
Imma be honest i HATE my skinnies!!! Not street friendly. Stopping sucks, no brake boosting, walks bad in the grooves, and tons of like roll or oversteer feeling in curves. Did i mention STOPPING SUCKS. Im on a bias ply i think they make a radial now that may help some but i doubt alot. But mine is a HARD driven street toy
08-12-2017, 06:36 AM | #400 | |
08-12-2017, 12:16 PM | #401 |
Well maybe I have found a suitable tire to fit the 17x8 Weld wheel.
Pirelli PZero 235/60R17 Now if Discount Tire can just locate some of them . . .
08-13-2017, 11:14 AM | #402 |
Sittin side ways
Drives: 2010 2SS/RS IOM Join Date: Nov 2012
I have 18x7 on the front of mine. I like that I can have a decent tire up front. I also do 1/2 mile events and like to stop.
850+hp club member
Procharger F1-A |
08-13-2017, 02:08 PM | #403 | |
So what tire are you using up front?
08-13-2017, 02:37 PM | #404 | |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
thanks
08-13-2017, 02:48 PM | #405 |
Not yet, but I will try to get it for you. The shop owner was not there Friday but his lead mechanic told me about the bolts.
08-13-2017, 09:48 PM | #406 |
Drives: 2013 Camaro 1LE Join Date: Nov 2013
Nice build for sure... I am sure ready to start mine. But in due time.
