Old 01-26-2015, 03:54 PM   #141
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Why no sticky yet?
A lot of questions regularly come up that are covered here.
Joe M 2012 2SS is offline   Reply With Quote
Old 10-25-2015, 07:19 PM   #142
Joe M 2012 2SS
Drives: 2012 2SS
Bump for beginners.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Old 10-25-2015, 07:39 PM   #143
Shawno72
Shawno72's Avatar
Drives: 2015 Black 2LT RS M6
Great write up
Shawno72 is offline   Reply With Quote
Old 10-25-2015, 10:32 PM   #144
JD_Alaska
JD_Alaska's Avatar
Drives: 2013 Camaro SS Coupe L99
Matt!!!!!! Come back!!!!!
JD_Alaska is offline   Reply With Quote
Old 12-27-2015, 07:25 AM   #145
Silverado60
Silverado60's Avatar
Drives: 2010 camaro 2SS/RS M6
Great thread!
Texas speed F-35 cam, rollmaster timing set, melling hp pump, ls2 chain damper, fluid damper 25% under drive, Che rocker bushings, tsp .660 lift valve springs, BBK CAI Amzoil filter with Phastek ww relocation and scoop, Gmpp axle back, Speed engineering 1 7/8" LT's no cats, Peak speed shop ported tb, NGK tr6, MSD wires, Amsoil Zrod wix, heritage grill, 1.25" BMR springs, MRR 228, Nitto Nt05,dyno tuned by complete street performance, elite eng catch can, clean side separator, Hurst shifter, Zl1 addon wickerbill
Silverado60 is offline   Reply With Quote
Old 12-28-2015, 12:32 PM   #146
Duke
Duke's Avatar
Drives: 2010 Red SS/RS
Thanks to the OP for starting this very informative thread. Since I just got my DA, I have some questions.
I've been using the GG 6" with a 4.75" BP for a week, just several hours a day. I use the Carpro velvet pad and M105 to remove some scratches and some of the factory orange peel.
Well, The M105 flashes pretty quick and I get the white patches and lots of dust. So, after watching some youtube vids, I began spraying the pad and the paint with detail spray before application of the M105. Now I can work the M105 much longer and no patches or dust. The surface looks great and now I'm wondering if I even need the polishing step. Any comment on polishing with Ultimate Polish after M105? Edit: I've done some some of the hood with Ultimate Polish and I can't see the difference between that and the M105.
Is there a downside to this technique?
I don't recommend the velvet pad for orange peel removal because it is very slow. But I can't recommend the denim pad because I haven't tried it. Any experience with the denim pad on factory clear coat?
Duke is offline   Reply With Quote
Old 12-28-2015, 09:06 PM   #147
Joe M 2012 2SS
Drives: 2012 2SS
Denim pad is much more aggressive, equivalent to 2000 grit sandpaper, where Velvet is equivalent to 3000 grit.
I've measured the total amount of paint on several Camaro's including mine. It's usually around 200 microns plus.. How much of this is actually clear?
No way to really know without a gauge that measures clear only, these start at around 2k, out of my budget.
The downside to removing a lot of clearcoat, is vehicle will be more susceptible to clear coat failure in the future, as it is thinner. Most of the UV protection is in the top layer of clearcoat.
105 is more aggressive then UP and will remove more paint.
If you want to proceed in orange peel removal, I'd stick with the slower process of the velvet, so you remove less paint, be very careful around the edges, in fact, if you can get some really small tape, tape them off, paint is much thinner on them and you can burn through it pretty quickly.
As far as finishing down, since you are using the Carpro Line already, Reflect polish will add more gloss to your finish. I haven't done orange peel removal on my Camaro, it's an un-garaged daily driver so no sense for me to, but here's a thread with results from Carpro Reflect and a Rupes 21 with Scholl Concepts Neo Spider "Honey" Pad.
http://www.camaro5.com/forums/showthread.php?t=427438
Old 01-13-2017, 10:02 PM   #148
Joe M 2012 2SS
Drives: 2012 2SS
Bump for tazman.
