08-12-2016, 07:48 AM | #113 |
Drives: 2015 Commemorative Edition Join Date: Jul 2013
They cut the bottom of the fender way to close. If you go back to stock you just won't have any support for middle of fender but as long as you don't have someone leaning against it you'll be ok.
Procharger D1SC - JDP ZR1 Cam - FAST LSX 102 intake, ARH , 729.7 RWHP 698 RWTQ |
08-12-2016, 07:51 AM | #114 | |
I have done several "back to stock" VDI cars and no problems encountered. The support for the middle of the fender is missing but you won't notice it once it's all back together. Sent from my iPhone using Tapatalk
08-12-2016, 11:46 AM | #115 | |
redleader
True. In your case I'd simply add a small sheet metal support using tiger seal as the glue. Sent from my iPad using Tapatalk |
08-12-2016, 12:18 PM | #116 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Completely reversible with note of what others have posted. Again though, you can open the door normally without the need to lift them.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
08-12-2016, 09:05 PM | #117 |
Drives: 2011 Camaro SS/RS Join Date: Jun 2016
Thanks for the input fellas. I've decided to look at a different car. This one is a good deal but it's not worth the effort to me.
