Old 06-06-2016, 11:04 AM   #1
blewbyyou
blewbyyou's Avatar
Drives: Dusk SE
To de can or not
So there has been a lot of discussion on weather or not a catch can will void your factory warranty. I noticed a sound I had not heard in the past. a ticking coming from the driver side closer to the fire wall and a hissing from the top or front of motor. So should I remove the can and go back to factory setup before going in for service? I don`t want to give them anything to blame the problem on or void my warranty because of the CC.
blewbyyou is offline   Reply With Quote
Old 06-06-2016, 11:09 AM   #2
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Is the Warranty still in effect on your car. You didn't list what year your Camaro is . Personally I wouldn't worry about the catch can being on .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 06-06-2016, 11:19 AM   #3
Bretts
SS
Bretts's Avatar
Drives: 2015 2ss rs
In Same boat lol
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
Bretts is offline   Reply With Quote
Old 06-06-2016, 11:22 AM   #4
Mr. Stacy
El Duderino
Mr. Stacy's Avatar
Drives: 2011 2LTRS Convertible
I would remove it before taking it in for service if you are still under warranty.
I bowl. Drive around. The occasional acid flashback.
Mr. Stacy is offline   Reply With Quote
Old 06-06-2016, 11:33 AM   #5
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
I'd remove it.
JLSuperfly is offline   Reply With Quote
Old 06-06-2016, 11:35 AM   #6
Stormcloak
slower than you
Stormcloak's Avatar
Drives: 2012 C6 Z06
Exactly this.
Stormcloak is offline   Reply With Quote
Old 06-06-2016, 11:38 AM   #7
jcampos
jcampos's Avatar
Drives: 2014 Chevy Camaro SS
I've had my catch can on for roughly a month and so far no issues to date.
I would remove it if I were you. That peace at mind is worth more than the time it takes to remove it and reinstall it upon return from servicing.
jcampos is offline   Reply With Quote
Old 06-06-2016, 12:05 PM   #8
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
If you have the ability to return to stock I absolutely would
Sent from my campfire using smoke signals
Superman09 is offline   Reply With Quote
Old 06-06-2016, 01:10 PM   #9
MSull16
MSull16's Avatar
Drives: '10 Camaro SS LS3
remove it man.
MSull16 is offline   Reply With Quote
Old 06-06-2016, 01:13 PM   #10
MjrStfy
MjrStfy's Avatar
Drives: 2015 Chevy Camaro V6 2LT RS
Just Scheduled a oil change for mine I plan on taking the catch can off.
Not to high jack the thread I have a cold air intake debating taking it off too? Yes my car is still under warranty.
MjrStfy is offline   Reply With Quote
Old 06-06-2016, 01:53 PM   #11
Ledzepx
Ledzepx's Avatar
Drives: 2010 2SS Camaro 6sp.
Take any mods off. Wouldnt chance it.
Ledzepx is offline   Reply With Quote
Old 06-06-2016, 02:48 PM   #12
JLSuperfly
JLSuperfly's Avatar
Not to high jack the thread I have a cold air intake debating taking it off too? Yes my car is still under warrenty.
Warranty.
Old 06-06-2016, 03:48 PM   #13
sdynak
Drives: 2010 1SS
Sorry.. is this really even a question?
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 06-06-2016, 04:15 PM   #14
MjrStfy
MjrStfy's Avatar
Originally Posted by JLSuperfly View Post
Warranty.
Fixed was at the Dentist in the waiting room reading the forums typing my question and hit reply fast, after they called my name to go back to see my Dentist. Bummer I didn't see her (she's kinda hot) ended up by seeing one of the other Dentist that work there. :(
