dave@hennessey
Old 05-04-2016, 01:08 AM   #1
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Rate my shopping list
Looking to either lessen or eliminate the rear wheel hop, along with stiffen up my drivetrain with some new mounts. How's my cart looking? Unless I'm missing something, the only thing i'm debating is switching to an adjustable toe rod instead. All rear end parts are BMR and the motor mounts are Prothane
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 05-04-2016, 05:45 AM   #2
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
Shoot an email to T.C. at bmrsales on here. He helped me with my setup below and I haven't heard one complaint (I'm away from the car until June).
Koni yellow shocks/struts and
BMR Suspension parts:
SP019 Lowering Springs Kit (Set of 4 1 Inch Drop)
SB030 Sway Bar Kit F & R
BK031 Total Bushing Kit Pro Version
SFC015 Subframe Connectors
DTB004 Drive Shaft Tunnel Brace
TR003 Toe Rods Adj
TCA026 Trailing Arm
TCA028 Lower Control Arms Non-Adj
STB014 Strut Tower Bar
ELK005 Front End Link Kit
FC002 Camber Bolts
What else can I do to my Camaro?
ticowarbird is offline   Reply With Quote
Old 05-04-2016, 12:03 PM   #3
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Get the BK024 Full Cradle Bushings - Pro Version!
Old 05-06-2016, 03:04 PM   #4
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
got it. i'm assuming those would replace the rear cradle bushings I have here?
Old 05-06-2016, 07:02 PM   #5
camaro2ss/rs
Drives: 2ss/rs
NICE LIST... BUT IF YOU ARE LOOKING FOR GET RID OF JUST THE rear wheel hop, that list is over kill.....
camaro2ss/rs is offline   Reply With Quote
Old 05-07-2016, 01:31 AM   #6
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
get full cradle bushings. the Delrin are the best. you can do aluminum too. There will be no noise adding solid cradle bushings. cradle bushing make a big difference.
Old 05-07-2016, 01:42 AM   #7
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
What would you eliminate then? I'm just following the thread found in the suspension section on eliminating wheel hop, wasn't sure if it was a "pick one" or "go for all three" so I figured the extra upgrades can't hurt.
Duly noted, I'll check them out.
Old 05-07-2016, 01:46 AM   #8
JCunningham
Drives: 2017 2SS M6
the motor mounts wont affect wheel hop but you will need all the rest.
Old 05-07-2016, 02:06 AM   #9
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Motor mounts are because mine are shot
Old 05-07-2016, 03:57 PM   #10
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
For sure. Stay away from inserts.
Old 05-07-2016, 07:34 PM   #11
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
I notice the bk024 is cheaper than the kit I have in here. Less parts? Not complaining about a smaller bill, just want to make sure I'm not missing out on anything
Sent from my Nexus 6P using Tapatalk
Old 05-09-2016, 11:29 AM   #12
BMR Sales
BMR Sales's Avatar
Drives: Race Car
That's because the Bushing Kit you originally selected also had Diff Bushings. I only suggest Diff Bushings if you are leaning towards a Track car only - the Diff Bushings will transmit a lot of Noise & Vibration.
The Cradle Bushings, you can go as hard as you want
Old 05-10-2016, 06:33 AM   #13
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Perfect, I can put that money towards a ported TB or udp lol, thanks!
