04-02-2016, 03:37 AM | #29 | |
Would this setup be recommended? Trans is stock and I do 1/2 mile events, 1/4 for fun, and road courses.
Update...Build in process, Forged Rods, Pistons and rings, Johnson Lifters, NOVI1500 ECS SC, 13lb boost or more, LS3 Conversion 114/228/241 COMP CAM, Frostbite 4 row Aluminum radiator, 6L80 built, Circle D 6L80 PRO SERIES MULTI 258MM 2D, Stock 3.45 gears, 1-7/8 American Racing Headers w/HF cat, X-Pipe, Lingenfelter dual fuel pump, E-85 flex sensor, ATI super damper pulley, Ported TB, 160 therm, Trans cooler, Pedder's sways/end links/sub frame bushings, BMR trailing arms & toe rods, Coil overs. HP/TQ pending
04-02-2016, 07:42 AM | #30 |
Drives: 2006 Z06 Join Date: Oct 2010
Whatever your drivetain will max out at, which on a auto car with a 6l80 is typically ~650rwhp or so.
Nick
Corvette Z06 -1200ish rwhp |
04-02-2016, 09:42 AM | #31 |
'It's an experiment'
If you add horse power, you'll eventually need suspension and cooling mods. It's part of the game. I did the LSA SC kit with cam and heads for around $7500 myself, but you find you need other mods to account for that change. I added a ZL1 pump and ADM FPCM right afterwards so that added to the cost. Later in the year on a hot day traveling, car temps got up there, so cooling upgrades came into play. Suspension upgrades will vey likely be needed for the additional power. I've done virtually all of those too. Upgrades to my intercooler pump and HX.
Design the kits (SC or Turbo) based on the feedback you get from the kit makers about your goals. They know what will work best. Turbo or SC, you'll need to plan on upgrades as you add bigger power, how much is up to you. -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
04-02-2016, 11:44 AM | #32 |
Drives: Anything I want Join Date: Oct 2008
I can do it
I can do the entire job with shipping the car to ADM and Back to your door for $11300.00.
Lsa conversion with fuel upgrades to 600+rwhp LS3 Conversion with ADM Stage 3 Cam for Auto Belts,Pulleys,Hoses,Injectors,Fuel pump,FPCM by ADM,Cam,Head gaskets,Bolts,ZL1 Intake,Tune,Labor Etc. Way over 550rwhp on 93 octane. My cell number is 214-228-8782 Leave a message if I don't catch it. Andy |
04-02-2016, 01:23 PM | #33 |
Installed that is a heck of a deal....
-Don
747 RWHP 794 RWTQ
04-02-2016, 06:44 PM | #34 |
Drives: IBM 2SS Join Date: Jan 2011
It can be definitely be done for under 10 but like others have said you have to turn your own wrenches. My tuner kit S/C sat for 4 months while piecing everything together. I just wasn't in a rush. Scanning the forums for different deals, and taking suggestions from my tuner to keep it safe. Thank you for all the people going in a different directions and selling their stuff at nice prices with low miles.
2010 SS, SLP TVS2300, 3.4 pulley, ZR1 injectors, MSD BAP, ZR1 map sensor, CAI intake, Custom Pat G tune, OBX long tube headers, Custom 3inch exhaust (no cats), Koni ST.R struts and shocks, Eibach pro kit sways and 1" lowering springs, CTS-V front brake upgrade.
04-02-2016, 07:12 PM | #35 |
Thank you everyone for the feedback. I am looking to get this done, but I have a tad bit to go before I get it right. I am already can LS3 converted. I do need to add power. Suspension is complete cooling for what I can do without the intercooler is done. The intercooler would be something important for me.o
04-02-2016, 07:34 PM | #36 |
Drives: Camaro ss 1le Join Date: Jan 2014
That is a very good deal Andy is giving you, Andy did my conversion a year ago and that was my DD i put about 21k on it since the conversion and very very reliable
04-02-2016, 08:13 PM | #37 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
Sell your car, save your $10-15k and get a 2012 ZL1. The ZL1 will be a better overall car and you can pull some great hp out of it with minor bolt ons and a tune. Fuel system, diff, suspension, forged sc motor and so much more. It will always be a more desirable car than a highly modded SS. The ZL1 is a multi purpose track car. IMO, your just throwing your money away.
04-02-2016, 10:16 PM | #38 |
Drives: All things Turbocharged Join Date: Dec 2010
Same exact advice I had given that you quoted (the turbos are now billet 54mm). Your first and super easy to get to step is 650whp. With your stall that's going to be an easy 10 second car with lots of room to grow when you want to upgrade your trans. Since you already have a cam it will only take like 8psi to make 650whp.
