03-29-2016, 09:26 AM | #1 |
Am I fu*kin myself?
Could I switch from running 50/50 water meth to running 116 race fuel in my tank and it still work? My meth is on order but I have 8 gallons of 116 going to waste.
I did a pull and my AFRs stayed in the 11s. I don't thing 50/50 water meth has near the octane rating of 116.
https://www.instagram.com/whoopa_ss/ |
03-29-2016, 10:13 AM | #2 |
Drives: 2010 Camaro Join Date: Nov 2009
If your running 50/50 mix you are not supplementing fuel, you are using it as a intake charge cooling method and the answer is no.
Use 100% Methanol and then yes, your accomplishing cooling and fuel supplement so the answer in your case is no. Look up Alky Control and read how you can use 100% Methanol to accomplish both. Also, a substitute is winter blend windshield washer fluid that is near 50/50 mix can be used if your out, but do NOT use 116 race fuel or any gasoline in the tank. |
