Roto-Fab
Old 04-24-2014, 07:03 PM   #57
Lio Martinez
Drives: 2013 Camaro 2SS RS 1LE IMO Turbo
Those WILL be making a return. Just hang in there.
Chase I'm curious to know the Sway bars you guys will sell will they be the same design as the Pfadt ZL spec ones!?
I had bought me a set for my project, but damn UPS lost the package just a day before I got them. So pretty much it looks like I'll have to find a new alternative.
Ok so I also got a Set of the Pfadt Front sway bar end links . Will those still work with the sway bars you are planning to make and sell!?
Lio Martinez is offline   Reply With Quote
Old 04-25-2014, 10:40 AM   #58
Powhusku
Powhusku's Avatar
Drives: 2010 2SS/RS M6
Powhusku is offline   Reply With Quote
Old 04-25-2014, 11:19 AM   #59
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Yes, they will be completely unchanged. You should have no problems using the Pfadt end inks.
Old 04-25-2014, 12:54 PM   #60
Lio Martinez
Please message me as SIMM as they are out? Will they take months to be out?
Old 04-25-2014, 01:20 PM   #61
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
Not completely true. Lio, if you got a hold of a set that were for the earlier Pfadt racing sways, they will have the 10mm heim joint on both ends. For the ZL Spec sway you need the 12mm thread. The bar uses the 12mm hole like the ZL1 does. The end links that came with the ZL1 Spec bars had 10mm on one end and 12mm on the other. The 10mm hole is for attaching to the strut. The ZL1 end links are 12mm on both ends and some guys just drill the strut hole larger. I believe you have the Pfadt coil overs so you have the 10mm hole.
Other than the heim joint thread size they are the same.
bannonm is offline   Reply With Quote
Old 04-25-2014, 01:28 PM   #62
Lio Martinez
The box and instructions said they were the Pfadt front end links for the ZL spec sway bars
It this ones. But just the fronts
http://www.pfadtracing.com/blog/wp-c...ks-Rev-3.2.pdf
Old 04-25-2014, 01:30 PM   #63
bannonm
bannonm's Avatar
You are fine then. I didn't know if you bought those used or new from someone.
Old 04-25-2014, 01:32 PM   #64
Lio Martinez
I bought the last set from JDP 3 weeks ago. Brand new for $100 shipped and the only bad thing is that is only the front ones. What can I do for the rear ones?
Any recommendations or will stick rear ones work !?
Old 04-25-2014, 02:16 PM   #65
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
You don't need the rears. Only the FE3's do. You are good to go when you do get the sways.
CHMSC is offline   Reply With Quote
Old 04-25-2014, 02:25 PM   #66
Lio Martinez
Great I just have to see if UPS finally funds the lost package. Or wait for Apex to develop theirs so that I can buy them from them
Old 04-26-2014, 04:16 PM   #67
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Got my springs yesterday! Can't wait to install.
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 04-26-2014, 08:08 PM   #68
Apex Motorsports
Thank you for your order. Be sure to post some pictures after you get them installed.
Old 04-26-2014, 08:10 PM   #69
Lio Martinez
Any idea of how long until the ZL spec sway bars??? just so we get a basic idea.
Old 04-26-2014, 08:57 PM   #70
Lio Martinez
That's is bad ass man. They still have the Pfadt Logo . Good luck with the install
apex motorsports, lowering springs, pfadt
