TireRack
Old 01-14-2014, 06:39 PM   #15
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
Sure! I will send one to you right away.
Jessica
Chevrolet Customer Care
Originally Posted by Tim Dula View Post
Jessica, Would you please email me? tds@blueridge.net I need your help.
Chevrolet Customer Svc is offline   Reply With Quote
Old 01-30-2014, 01:23 PM   #16
aaronbv16
Aaronbv
aaronbv16's Avatar
Drives: 2010 Camaro RS/SS Victory Red
I have had the same issues today. It has been raining all day and there is water all in my trunk. My car isn't a Convertible. When I took a look inside the trunk the leak seemed to come from the rubber gasket going to a rubber hose coming from the rim of the trunk lid. I am currently overseas so I cant take it to a chevy dealership. Any suggestion's?
aaronbv16 is offline   Reply With Quote
Old 01-30-2014, 01:25 PM   #17
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Sunroof? It may be your drain has either come loose or clogged.
The Bird is the word!
Old 01-30-2014, 01:46 PM   #18
aaronbv16
Aaronbv
aaronbv16's Avatar
Yeah I have a sunroof. Is that where the little rubber hose that runs to the trunk lid from? I did check the hose and it was a little loose. It seems to be cheaply made. Doesn't seem to have a zip tie...nothing to connect it to the drain onto the trunk lid.
Old 01-30-2014, 01:54 PM   #19
Angrybird 12
Check some of the earlier posts in the thread, I think there were a few that told how to fix it.
Old 02-17-2014, 04:03 PM   #20
viper2183
Tampa Bay Camaros
viper2183's Avatar
Drives: 2012 Camaro SS 45th Anniv. Edition
Just went into my trunk and behold wet. Along with some documents I had brought home from work
Thanks,
Dan B
viper2183 is offline   Reply With Quote
Old 02-18-2014, 09:54 AM   #21
viper2183
Tampa Bay Camaros
viper2183's Avatar
checked for drain tubes in trunk and found the left one off..... easy enough fix
Thanks,
Dan B
Old 05-03-2014, 10:44 AM   #22
Twonz360
Twonz360's Avatar
Drives: 2011 Black 1LT RS
I am having the same issue.
Mods:
Performance
Elite Engineering Catch Can, VMax CNC Ported Throttle Body, CAI Inc. Cold Air Intake, ARK N2 Catback Exhaust, Trifecta Tune, RX Ported Intake Manifold (Custom Paint Job), MACE 25mm Insulator, ARH Long Tube Hedders,
Misc.
Magnetic Oil Drain Plug, Royal Purple Oil, LED DRL's, Blacked Out Bow ties, Sound Deadening In Trunk, LED Interior & Trunk, AAC LED Side Markers
Coming Soon...
SS Rear Diffuser, JDP Motorsports RS Color Changing Halo Package, SS Front Bumper..... Cams.:slice: "I'm Killin' em"
Twonz360 is offline   Reply With Quote
Old 06-29-2014, 09:08 PM   #23
Twonz360
Twonz360's Avatar
Had the dealer check and found the leak from a seal around my back window. It was "worn out". They removed the glass and reinstalled with better seals. Two months and no problems!
Mods:
Performance
Misc.
Coming Soon...
Old 08-14-2015, 11:16 AM   #24
Duflar
Duflar's Avatar
Drives: 2011 Camaro 2SS RS
can anyone tell me what the name and or part number is for the grommet in the trunk that the drain hose attaches to? I had body work done over a year ago and fond they didn't re-install that grommet, they left the drain hose hanging in the air.
<img src=http://www.camaro5.com/forums/image.php?type=sigpic&userid=31288&dateline=1309279779 border=0 alt= />
Duflar is offline   Reply With Quote
Old 08-14-2015, 04:17 PM   #25
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
I had this problem with a sunroof drain in a 1980's cavalier. Amazing that GM is still making this crappy part the same way. That car would get an inch of water in the spare tire well whenever it rained.
My Camaro has no sunroof and no leak.
Old 11-03-2015, 11:52 PM   #26
Dan1028
Mechanical Engineer
Dan1028's Avatar
Drives: 2012 IBM Camaro 2SS/RS A6
The passenger side of my trunk just below the lip nearest the rear windshield is a wet mess right now. This is the second time I've noticed it happen. The first time was months ago, this time was after a car wash. I have a sunroof, but the grommets look secure.
I called my dealership and they said they wouldn't even look at it. Chevrolet Customer Svc, any help here? My car is a 2012 and, admittedly, is just past the bumper-to-bumper period. But why would the dealership refuse to even look at it and offer me a price to repair?
Current Vehicle: 2012 Chevrolet Camaro SS
Past Vehicle: 2001 Honda Prelude SS
LEFT HAND DRIVE
Dan1028 is offline   Reply With Quote
Old 11-04-2015, 02:25 AM   #27
MrChrisLS3
Drives: 2018 1SS M6
Originally Posted by BubbaSS View Post
My trunk started leaking recently...no sunroof :\
Mine did too, just the other day as a matter of fact. Not so much as drop before that. Weatherstrip looks fine, although I can tell it leaked from where the cable goes in.
We had two days of steady rain. There are also a lot of trees with smaller leaves. I wonder if the drainage is blocked where the water flows at the bumper cover behind the lights?
MrChrisLS3 is offline   Reply With Quote
Old 12-21-2017, 04:54 PM   #28
Storm T
Can't slow down
Drives: 2013 SS Dusk Edition (Insain Bolt)
Me too
I just had to put a new battery in my 2013 Dusk Edition. Sure enough, under the carpet down in the battery compartment there is a 1/4 inch of water! No idea how long it's been like that. This appears to be a common issue. I sure hope it's fixed for free. This can't be good. Does anyone have any pictures of said hose? I sure can't seem to locate it? Do you have to move the carpeted panel on the side or what?
Thanks!
EDIT: Well, never mind. That was absolutely my issue as well. I was looking farther back instead of up close. Found it and fixed.
Storm T is offline   Reply With Quote
