02-12-2014, 10:41 PM | #1 |
Drives: 2012 Camaro 1SS Join Date: Oct 2012
20x10 w/ 45mm Offset All around
Would 4 20x10's with 45mm offset fit on all four corners with a 275/315 Combo?
02-12-2014, 11:55 PM | #2 |
Quit being a pu$$y
No.
02-13-2014, 05:55 AM | #3 |
Drives: '20 Corvette Stingray Join Date: Jul 2009
no way.....not even close
02-13-2014, 09:47 AM | #4 |
Thanks for the answers on fitment. Am I correct in assuming the the offset is too much and positions the rim too far into the front wheel well and contacts the suspension?
02-13-2014, 10:06 AM | #5 |
That is absolutely correct.
02-13-2014, 10:42 AM | #6 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Most of the posts with 10" wheels in the front show offsets in the 20-30mm range. I believe the ZL1 replicas are 23mm and fit fine.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
