01-07-2014, 01:28 PM | #15 | |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
You may want to consider hex vents I am sure you could get them to work.
The Bird is the word! |
01-07-2014, 01:40 PM | #16 |
If no one responds to this request, I will measure mine tonight for you.
01-07-2014, 01:40 PM | #17 | |
Drives: 1987 Corvette TPI Join Date: Mar 2012
01-07-2014, 01:42 PM | #18 |
Thank you!
01-07-2014, 01:48 PM | #19 |
I would go out and measure mine but it's under a blanket if snow and it's 10F outside.
01-07-2014, 01:53 PM | #20 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Just in front of the scoop openings, it's about 21-7/16" wide. About 6" from the rear of the insert, it's about 23-3/4" wide. About 40-1/2" long from front point to the back.
All measurements done by my wife's super-accurate (yeah, right) cloth sewing measuring tape and thus listed as approximate. But this should give you an idea.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
01-07-2014, 01:54 PM | #21 |
I understand, thank you.
01-07-2014, 01:55 PM | #22 | |
01-07-2014, 01:58 PM | #23 |
Are you sure it will apply downforce? GM spent a lot of money and man hours in the wind tunnel to get this system to work on the ZL1. No doubt it will look cool, though. Good luck with the project.
01-07-2014, 01:58 PM | #24 |
I just measured the cowl on my C4 and it should fit just about perfect! A little modding is understandable as this is not going on a Camaro. I'll also welcome other measurements
01-07-2014, 02:05 PM | #25 |
Yes it should, the air goes just under the nose through the radiator then out the ZL1 extractor hopefully
01-07-2014, 05:31 PM | #26 |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
Unless you make provisions for the catch basin over your radiator as the ZL1 has you will get water runoff into the engine compartment.
01-07-2014, 07:27 PM | #27 |
look at a pic of the insert. It is 41" from the cowl to the front point center to center. It is 22 1/2" wide at the center point of the hood.
01-07-2014, 08:13 PM | #28 |
It will clear the engine plenty, my worry is it actually going to far forward and touching the radiator.
