05-09-2024, 08:24 AM | #351 | |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
05-09-2024, 10:23 AM | #352 |
There are some out there that are quite the contrary and post numbers that as asininely high. You can always tell from the baseline. When stock LT4 cars make 580RWHP you know its "fairy power" as we call it.
05-09-2024, 11:10 AM | #353 |
Mike, what is your take on the % of change between Mustang and Dynojet tune numbers?
05-09-2024, 11:57 AM | #354 |
05-09-2024, 12:06 PM | #355 | |
Drives: 2023 ZL1 - Modified All Bolt On's Join Date: Dec 2022
https://www.camaro6.com/forums/showthread.php?t=585756
2023 ZL1 Auto - CSP 2" Long Tubes by Stainless Works | Gesi G-Sport High Flow CATs | Stainless Works Legend NPP Axle Back | Roto-Fab Big Gulp | Kong NM103mm | Kong X-Port | Griptech 2.3" Upper | ATI Super Damper w/18% 9.45" Lower | TooHigh PSI Port Injection w/875cc Injectors | E85 | Brisk RR14S Plugs | Granatelli Malevolent Coil Packs | Katech Low Profile Billet Valve Covers | Katech Duel Fuel Pump System | MightyMouse Wild 1000HP CC | DSX Flex Fuel Kit | DSX Billet Lid | DMS 2gal Fender Tank | NT555R2's 305/285 | Katech Tuned
05-13-2024, 02:21 PM | #356 |
Update: Received my Baseline Dyno from Mike just now! On around E15 and with it running out of fuel pressure around 5600 RPM (It's dropping between 400psi to 600psi below command), here are the results !!! I know there is probably some level of belt slippage, I have a stock length green belt installed. After getting my blower back from Kong after the X-ported was done and the 2.3 upper was installed. I was unable to get the smaller green belt installed. Probably due to the FI Interchillers block plates I installed as these raise the blower about a 1/4 higher.
THANKS MIKE !!!
05-13-2024, 04:09 PM | #357 |
Snackbar Tuning
dropping from 400psi to 600psi?
GM Gen V Calibrator
05-13-2024, 08:17 PM | #358 | |
Having FUN in the SUN...
Good news, she is in good hands now!
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi |
05-13-2024, 08:39 PM | #359 |
So that should have read... fuel pressure is dropping between 400psi to 600psi below command at top.
05-21-2024, 05:52 AM | #360 |
Update: Katech let me know yesterday that the car is on a lift and is being worked on!!! I feel that's about a week later than the original time frame Mike and I talked about. But, I knew that the jobs ahead may/could run into issues that would delay their completion and delay the start on mine. Katech will provide photos as the work progresses and I'll update them here as soon as I get them!!
05-21-2024, 08:08 AM | #361 | |
05-29-2024, 06:29 AM | #362 |
Update: Mike from Katech emailed yesterday. He said my Camaro is on the lift and work has started and they will make a lot of progress this week. So, more photos to head my way! It will probably be sometime next week or worse case, the being of the following week (I hope) when I go get her! It's a bit weird walking into the garage and seeing the empty spot where I normally park my Camaro! Adding to that, I've noticed a few things starting to creep their way into the garage floor area where it's normally parked! I quickly told everyone in my household there will be no disrespecting the Camaro while she's visiting Katech! They looked at me like I was an alien from another planet! Perfect, that must mean they know I'm serious!
Dampener and larger 9.45" lower installed!
05-30-2024, 06:18 AM | #363 |
Update: Mike sent additional progress report and photos at the end of the day yesterday! 1) Exhaust is off in preparation for the fuel tank to come out, 2) Wheel well liner is out in preparation for the fuel pump controller to be routed and 3) New valve covers are installed. Not pictured but being worked on. 1) Port plates assembled, 2) Fuel lines being built. Needed to order 2 more fittings which should be here tomorrow. I have to admit, these Katech low profile valve covers are pretty dang sweet looking !
05-30-2024, 08:42 AM | #364 |
Damn... she is coming along quick now! Super exciting!
She is going to be one hell of a sleeper!
