05-05-2024, 02:43 PM | #1 |
Drives: Chevy Camaro Join Date: Dec 2019
Rear Quarter Window Adjustment?
I have a 2017 Camaro - the other day I had noticed that the rear quarter window on the driver side doesn't go up as high as the driver side window. The Passenger window and rear quarter window goes up flush with each other. I have a convertible, especially noticeable when the top is down, but you can see it with the top up when you look closely
It's off by about 1/2-3/4"... anyone know how to adjust it? I've tried disconnecting the battery 30 minutes and re-indexing it but no change... This could explain why I notice more wind noise on the driver side than the passenger side. |
05-06-2024, 10:13 AM | #2 | |
Drives: 2023 Camaro Convertible ZL1 A10 Join Date: Mar 2023
05-07-2024, 11:58 AM | #3 | |
I pulled the ground again and plan on letting it sit for 3 hours before trying it again as it occurred to me the car never prompted to reindex the windows when I had tried it before (disconnect for 30 minutes). Keeping my fingers crossed.... Otherwise I may just have to keep the radio turned up to drown out the wind noise... |
05-08-2024, 03:44 PM | #4 |
When I reconnected the battery ground after 3 hours, I did get the Open and Close window message on the dash. I did the front driver window and then the front passenger window but it never asked about the back quarter windows...
I opened and closed them as well but no change... The driver rear quarter still stops lower than the front window (passenger side they are even) I may take it to a bodyshop to see if they have any ideas.... |
