05-06-2024, 09:15 AM | #1 |
Drives: Z06 Join Date: Jul 2010
20x10 and 20x12 on 2010
Can’t find in my search wheels this size and offset but I’ve Found a set of wheels that I’d like for my car but rears are wider than I was expecting. They are currently on a 6th gen in the pic attached. Wondering if anyone knows how these will sit/fit on my 2010?
Specs are: Fronts 20x10 with 6” backspace (sorry he told me backspace instead of offset) with a 255/40-20 on them. Rears are 20x12 with 7-5/8” backspace with 305/35-20 on them. Thanks for any input I think in calculating offsets are +12.5mm front and +28.5mm rear Edit: the offset numbers above are from using an online calculator. However when I add it myself I get fronts at +25mm and rears at +41mm.
05-07-2024, 09:39 AM | #2 |
What wheels are they? I wanted to go with 12 wides on my rear, but was told by APEX wheels that I would have needed to go with a set of 19's to do that because there were NO 20's made that would fit the 5th gens.. So I currently am running 11.5 on the rear with a +30 offset.. Feradda FR3's..
05-07-2024, 10:09 AM | #3 |
XO Luxury "Caracas Titanium Polished". https://www.camaro5.com/forums/showt...hlight=caracas
in 20x12 rear 315/34 and 20x10 front 275/40 with just a tiny bit of rubbing pitching it hard into a curve. But that is with all Z28 suspension plus solid subframe bushings. |
05-07-2024, 12:47 PM | #4 | |
Drives: 2011 2SS/RS Join Date: Feb 2016
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
05-07-2024, 01:39 PM | #5 |
Gtstory, what are your offset numbers front and rear?
05-07-2024, 01:41 PM | #6 |
1JEWLDSSRS they are forgeline monoblock se1
05-07-2024, 01:42 PM | #7 |
05-07-2024, 01:51 PM | #8 |
It wouldn't surprise me if it isn't the same as what is shown here for the corvette but I don't know for sure.
https://www.corvetteforum.com/forums...and-20x12.html |
