04-29-2024, 07:19 AM | #29 |
Drives: White 2024 1SS M6 Join Date: Nov 2023
Yes as a whole I've heard very good reviews on the Atturos, and for the price they can't be beat, plus I like the look of the tread pattern. I was originally set on Nitto 555 G2's, but I simply don't like the way the tire looks. Petty I know, but the primary reason for swapping new tires/rims is aesthetics, I'm not tracking the car or driving in anything other than warm sunny weather. I'm still on the fence on whether to go with Gloss Black or Gun Metal MRR's , but I'm leaning heavy towards Gloss Black.
04-29-2024, 02:54 PM | #30 |
Drives: '23 LT1 A10 Join Date: Oct 2015
IMO gloss looks best on fancy cars. I probably would not go with Atturos but I guess they could be better than the run flats.
24 LT1 M6 Sharkskin Metallic
14 Mazda Mazda3 S Grand Touring (Daily) |
04-29-2024, 02:58 PM | #31 |
wont the 35 series rub the strut in the front?
04-29-2024, 04:01 PM | #32 |
2020 Shadow Gray 2SS
I don't think they will, they will be the same height as the OEM 245/40's that were on there. I currently have 285/30's on the front, so 275/35 will be slightly taller (but no taller than the OEM 245/40) and slightly narrower...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Fender Badge, Footwell Lighting
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
04-29-2024, 07:46 PM | #33 | |
Yes the factory 245/40/20 are approx 27.7" tall and 9.8" wide. The 275/35/20 are approx 27.6" tall and 10.9" wide. The 285/30/20 are approx 26.8 tall and 11.4" wide. I believe there is a slight difference in the factory rims having a 20 offset, and the MRR's having a 23 offset. |
04-29-2024, 09:26 PM | #34 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
Not sure I was discussing this with you a few weeks back, but keep in mind your speedo. I have the 20x10s all around with 285 30 20s and my speedo is off by 2-3 mph, depending on speeds (the higher the speed, the more the variation. 75mph on speedo is actually 72. Otherwise, 0 complaints.
"Make yourself sheep and the wolves will eat you"
04-29-2024, 10:10 PM | #35 | |
04-30-2024, 07:42 AM | #36 | |
Yes that was me....I really like the look of your square set-up. The 285/30's are about an inch shorter than factory spec, so they will definitely throw off your speedo, as would a taller 305/35 or 315/35. The 315/30 is essentially identical in height to the factory 275/35 rears. I use the online calculator to show offset and mph variances with different wheel combos. https://www.willtheyfit.com/index.ph...=10&offset2=23 When comparing the factory front 245/40/20 on a 8.5" rim 20 offset, to a 275/35/20 on a 10" rim 23 offset, I just don't see how the 10" front rim will clear the front strut brace, do you have any issues with rubbing in the front ? I don't have mag ride if that makes a difference. |
04-30-2024, 12:50 PM | #37 | |
04-30-2024, 01:11 PM | #38 | |
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
04-30-2024, 01:18 PM | #39 | |
04-30-2024, 01:28 PM | #40 | |
I have pictures of that on my car with 275/30R20's 285's fit better on the 10" wheel, the rest regarding offset has to do with internal rubbing inside the wheel well, mainly with suspension linkages if I am not mistaken. You would see rubbing on the inside of the tire. And some people have shown pictures of it stripping the tire down to the wire. So premature tire wear. I guess 275/30 would be the smallest I would go on a 10" rim, 265's will likely not fit the rim itself due to sealing issue. I guess that would translate to less tire flex on hard turns? The 35 aspect should help with tire flex in that case. 275/30R20 on 10" rim with ET 20 285/35R20 on 10" rim with ET 20
04-30-2024, 02:05 PM | #41 |
If the factory 8.5" rim is a 25 offset, that would explain why there is minimum clearance between my rim and strut. The clearance is maybe pinky width at most, I would think a 10" 23 offset rim would rub, or be within a hair of rubbing the strut.
Does anyone know if Mag Ride has the same clearances as non Mag Ride? |
04-30-2024, 02:09 PM | #42 | |
Either way, a 10.0" wheel is right in the middle of both tires recommended wheel width... I don't think they rim will stick out beyond the sidewall of the tire on the 275/35's on a 10.0" rim...
