06-23-2023, 04:20 AM | #1 |
Drives: 2019 2SS Riverside Blue Join Date: Aug 2011
For those Contemplating MBRP Exhaust
I bought my car brand new in 2019. The stock exhaust sounded way better than the stock I had on my 2011 thanks to the NPP and an awesome factory tune.
The problem I had with it? While it sounded good launching from a start, the pipes got too quiet at cruising speed. Changing modes didn't help so i pulled my NPP fuse to keep the valves open. Much better but still didn't ring my bells.....thanks in part to Ozzy Osbourne blasting through my 1984 speakers while cruising High School hangouts. My ears require more volume and depth from the car. I did a lot of research on how to improve on the sound without breaking the bank while at the same time not having drone. I was hooked on videos of Borla Atak but not very hooked on the price. I came across videos of MBRP and heard the comparisons and I was sold. Knowing I would lose the option of closing valves, I didn't care very much since my fuses had already been pulled for some time. After my interest peaked on MBRP, I watched every video available on Youtube comparing Axleback vs Catback. I was undecided so I came here to read up on some feedback from those who bought both. Many were saying that due to the X pipe, the Axlebacks were better than the Catbacks. I decided to pull the trigger and hopped onto the MBRP website and selected the middle grade Axleback setup. I live in Oklahoma. We don't get a lot of snow so the salt factor was minimal when considering the concerns of rust. I paid 690 bucks and it was delivered in 3 days. MPRP sent me an email with a link to track the shipping. I got with a local shop to install it. He had done Borla and Flowmaster but hadn't heard of MBRP but was more than willing to do the install. He bolted it on in 2 hours and I started it up. He was blown away, as well as I was. He said my exhaust sounded as good or better than the Borla installs he has done on Corvettes that cost over 2 grand. While doing my video research, many had said that the exhaust sounded the same as stock on on the inside the car but that is totally not true. While the sound on the outside was awesome, I was blown away by the sound on the inside. I had my rear seats down to accommodate the room needed to transport the exhaust system to be installed so the seats were still down when I started it and got inside (There is plenty of room to load the kit into the trunk via the backseat if you drop the back seats and forward your passenger seat all the way up). I kept the seats down for the ride home and I was in heaven. There is no drone, it sounds like a different car and makes me think for what we pay, they should sound like this when we buy them. The sound was total power. The tone was so deep and loud. downshifting is magnified by 10. My installer took pictures of the set up under my car as well as the box the kit was shipped in. He said he was going to recommend MBRP to anyone willing to pay for Borla or Flowmaster. I think he was more excited than I was. Videos on Youtube do not do this exhaust justice. You just can't hear the difference in tone and power. If you are looking to upgrade your exhaust system, I highly recommend MBRP axelbacks. You will not regret it. Thanks! Last edited by RIPws6; 06-23-2023 at 04:31 AM. |
06-23-2023, 06:39 AM | #2 |
I too like MBRP. I had a great touring system on my Mustang GT and chose it for my ZL1. I did upgraded Carbon Fiber tips though which I bought separately. MBRP has the best price point on exhausts.
06-23-2023, 06:59 AM | #3 | |
Drives: 2022 camaro lt1 Join Date: Apr 2023
06-25-2023, 03:48 AM | #4 |
04-17-2024, 01:18 PM | #5 |
Drives: 2017 SS Camaro Join Date: Feb 2022
If you are looking to upgrade your exhaust system, I highly recommend MBRP axelbacks. You will not regret it. Thanks![/QUOTE] Did you also get the xpipe installed with the axle back? |
04-18-2024, 08:41 PM | #6 | |
I did not. Do you have them? Curious if anyone got them thought it was worth it or if the could compare the difference. I know I’m still way happy with mine. The next thing that happens is you get pissef at your AFM for shutting off the sound. I’m getting a Range device to fix that issue. |
04-20-2024, 12:08 AM | #7 |
Drives: 2016 Black 1SS, M6, NPP, Mag Ride Join Date: Nov 2023
I need to check into if they have a setup to work with my NPP. Love the sound. Was always a Magnaflow fan because of the deeper sound, but prefer the MBRP.
04-20-2024, 09:22 AM | #8 |
Drives: 95' camaro Join Date: Feb 2015
I am running the MBRP race profile cat back and love it. I will say, after switching to long tube headers, the sound is a lot more agressive, yet still no cruising drone.
04-20-2024, 11:41 AM | #9 |
Well, I do have headers, xpipe, and axle-back, catless, and a cam. I will tell you it is loud on my car. There is drone, but I am used to it doesn't bother me. And the idle chop is awesome. And at high rpm actually sounds like a racecar.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
