Go Back   CAMARO6 > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
BeckyD @ James Martin Chevy
Old 05-11-2023, 01:29 PM   #15
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
Originally Posted by FollowMyLine View Post
The Blackwing duct will fit regardless of what shield is at the back of the rotor. To get the full functionality, you would want the mini shields installed.
The SS hasn't come with the track brake kit in a very long time. I believe that was a 16-17 only, and my 2018 did not include them, and my 2022 didn't either.
I have a 2018 that I ordered new, and they came with the car (your dealer may have tossed them). This may no longer be the case after the 2019 refresh indeed.
735 rwhp | 665 rwtq
3000 - 2/06/18 TPW 2/26/18
Old 05-11-2023, 10:29 PM   #16
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Interesting! I found my 2018 on the lot, ordered my 2022.
Luan Zeqollari
2022 Camaro SS 1LE M6 - Wild Cherry Tintcoat - Delivered 9/20/21
2018 Camaro SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 10-14-2023, 03:42 PM   #17
zapp
zapp's Avatar
Drives: 2022 ZLE 6M
FYI - There is a Kit for the rear:
GM 85523690 DEFLECTOR KIT-FRT BRK CLG
https://www.gmpartsgiant.com/parts/g...-85523690.html
zapp is offline   Reply With Quote
Old 10-16-2023, 08:55 AM   #18
FollowMyLine
Driver for Hire
Is this different than the rear numbers I posted?
Luan Zeqollari
YouTube Channel
Old 12-13-2023, 03:36 PM   #19
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
I finally received my Blackwing Brake Cooling Ducts after 3 months of order cancellation and reordering, what a size difference from stock ZL1. I don’t seem to have much of a dust shield so that’s good
I must be blind or stunned? For the love of God, I can’t figure out how the rear cooler deflectors fit. #84946131,32 edit: Ok figured it out, I need to drill holes and make spacers
CalgaryZL1 is offline   Reply With Quote
Old 12-13-2023, 06:54 PM   #20
FollowMyLine
Driver for Hire
EDIT: Rear arms were changed for 2022. Here is the part number for the ZL1, SS 1LE and ZL1 1LE.
85004630 - Rear Trailing Arm (FE4/FEA)
You shouldn’t need to drill any holes. Should already be there. There are part numbers for the spacers, too.
Luan Zeqollari
YouTube Channel
Old 12-14-2023, 04:42 AM   #21
CalgaryZL1
CalgaryZL1's Avatar
Reading other threads, apparently model year 2022 and up have the holes, is my understanding. I didn’t realize there was a rear kit, so I ended up ordering the two individual part numbers and I don’t know the part number for the spacer.
Old 12-14-2023, 09:51 AM   #22
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
Here's a step by step video tutorial for the rear. I checked my 19 1LE and the holes weren't there on mine either. You will have to drill if not.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 12-14-2023, 01:07 PM   #23
CalgaryZL1
CalgaryZL1's Avatar
Thanks for the info! I just decided to order the upgraded arms with the holes, they are only $66 US a pair. With the apparent flex of these arms, I want to eliminate any notch affect from drilling a hole with the drill bit.
Old 01-31-2024, 03:49 PM   #24
KirillWA
KirillWA's Avatar
Drives: 2022 Camaro 1SS 1LE
I have holes in rear control arms on my 2022 SS 1LE and half-size dust shields in the rear.
I've decided to go with 85523690 kit for the rear instead of buying ducts and hardware separately, and ordered Blackwing ducts and mini dust shields. Appeared to be less then $100 in total, and I hope I will get the delivery soon
2022 Camaro 1SS 1LE Rapid Blue 6MT
Looking for traction on wet pavement in Seattle.
KirillWA is offline   Reply With Quote
Old 01-31-2024, 05:30 PM   #25
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
Damn the front hang low...
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can
Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster
ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar
DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi
SOCAL.M6.ZLE is offline   Reply With Quote
Old 03-04-2024, 04:16 AM   #26
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Good info, thanks
carguy55 is offline   Reply With Quote
Old 03-04-2024, 06:55 AM   #27
FollowMyLine
Driver for Hire
Updated the first post with more part numbers:
23385146 - Front Left Mini Dust Shield
23385147 - Front Right Mini Dust Shield
85536980 - Front Right BW Brake Cooler
85536981 - Front Left BW Brake Cooler
84946132 - Rear Right BW Brake Cooler
84946131 - Rear Left BW Brake Cooler
84946133 - Rear Thread Insert for Screws
85523690 - Rear Cooling Kit
11548166 - Screws x6
Luan Zeqollari
YouTube Channel
Old 03-04-2024, 09:01 AM   #28
FactoryMatt
FactoryMatt's Avatar
Drives: '22 2SS 1LE
For SS 1LE guys you definitely need smaller front dust shields or have to cut the OE. The stock ones block the ducts.
FactoryMatt is offline   Reply With Quote
