05-12-2023, 06:48 PM | #197 | |
Drives: 2013 BRM ZL1 Camaro M6 Join Date: Feb 2014
I had purchased all the Morimoto projector, and HID and halo upgrades some time ago, and have not installed anything as yet. These brackets will be much better design in mounting than I had originally planned. Thank you so much for sharing. |
05-12-2023, 09:42 PM | #198 |
Drives: '11 2SS/RS M6 Join Date: Dec 2010
What grits you go with? I usually 1000, 1200, 1500, 2000, then use Chemical Guys products.
05-13-2023, 04:12 PM | #199 |
Drives: 2011 2SS/RS Join Date: Feb 2016
You sir LINK ME to your products for sand paper. i neeeed to gorder some.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
05-13-2023, 04:14 PM | #200 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
I see you did that while on the car? How did you protect your fiberglass front bumper cover? Did you tape it off? Sent from my iPhone using Tapatalk
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
05-13-2023, 04:19 PM | #201 |
EVERYONE. I have created a new thread specifically for the write up and install as this page is to be retired (nolonger a group buy)
05-14-2023, 07:45 PM | #202 | ||
Chemical Guys BUFX_104HEX4 BUFX_104_HEX4 Hex-Logic Light-Medium Polishing Pad, White (4.5 Inch Pad made for 4 Inch backing plates), 1 Pad Included https://a.co/d/1Xsr8Ko Chemical Guys BUFLC_BP_D2 Flex Pro Professional Backing Plate with Drill and Dual-Action Adapters (3.5 Inch), Yellow https://a.co/d/bbOuURa Chemical Guys BUFX_102_HEX4... https://www.amazon.com/dp/B003Z9VMX2...p_mob_ap_share Quote:
I just re-read my post you quoted and noticed I made it seem like all I did was use sandpaper to get that clear. The 1st pic is the headlight sanded and the 2nd is after using V34, 36. My bad for misleading. Sannding products are nothing special, I just grab the sandpaper from AutoZone - 1000, 1500, 2000, P3000. After I sand I use 3products from Chemical Guys. 2 are compounds V34 and V36. I use V36 first and then finish with V34. After that for protection I use Chemical Guys Jet Seal. Apply it, let it sit for about 30mins, wipe off. V34 on Amazon https://a.co/d/awnXazK V36 on Amazon https://a.co/d/e483lvW They make two other compounds V32, V38 which I also have but never used. Apparently those are for headlights that are extremely bad. Another pic of another car I did using the same products. Left side restored right side, well, yea... Last edited by rsrsrs; 05-14-2023 at 08:03 PM. |
05-14-2023, 09:01 PM | #203 | |
12-30-2023, 09:34 AM | #204 | |
Drives: 2012 2LT/RS Join Date: Oct 2011
Really sorry to miss out but wanted to say THANK YOU!
12-30-2023, 10:10 AM | #205 |
You can still get the brackets but without the discount
