03-14-2022, 06:49 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Jan 2019
Need Cam help
Just installed a Btr stage 2 N/A cam to a L99 with vvt and dod delete and the car is lunging forward when it’s downshifting to 2nd and 1st gear. I’m having to put it in neutral when I’m stopping at a light or stop sign. Do I need a torque converter?
03-14-2022, 08:15 PM | #2 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
New tune for new cam???
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
03-15-2022, 06:57 AM | #3 |
It’s been tuned and everything at the shop. It shifts good and everything it’s only whenever I’m stopping and it downshifts into first
03-15-2022, 07:45 AM | #4 |
Not a lot of info to go on here.. Is a stall converter recommended for that cam?
03-15-2022, 08:17 AM | #5 |
It states that stock converter works perfect with this cam. Here’s the link to the cam https://briantooleyracing.com/btr-ca...-32538134.html
03-15-2022, 10:04 AM | #6 |
Drives: 2014 Chevy Caprice PPV L77 Join Date: Jun 2021
I have the same cam and understand exactly what you mean. The factory converter is tight. At low rpm the cam has a natural lope and more overlap so you get the lope and bucking/surging. With the factory tight converter it transmits that force and you feel it. You can tune some of that cam surge out so it will idle nicely but to get rid of that surging/bucking/push on brakes you need a looser converter. Oddly enough I just ordered mine yesterday from Circle D. I am tired of it myself. LOL. You shouldn't be stalling. Sounds like idle and drivability is not properly tuned. With a good tune you can run a factory converter with that cam, but based on my experience you will have much better drivability with a new torque converter. If I were you I would go back to the tuner, take him for a drive, and have him fine tune it. If he can't/won't then would look to the likes of Pat G, Shane H, etc. to have it fixed. Either way if you want better drivability I would consider a converter as well.
2014 Caprice PPV, 6.0L, BTR Stage 2 LS3 N/A Cam, 2" ARH, 3" custom exhaust, 3.45, Circle D triple disc converter, Lloyd Elliot heads, Rotofab intake, Chris Henry tuned, future LSA....
03-15-2022, 10:57 AM | #7 |
Thanks
03-15-2022, 01:01 PM | #8 | |
03-15-2022, 01:10 PM | #9 |
Sorry I can't give you good advice on that one. I don't have enough experience. Circle D recommended I go with a 258mm, triple disc, 3200-3400 for my setup (14 Caprice, 3.45, 4300 weight with full fuel and driver, NA now but going LSA in 3-5 yrs). Give me 2 months and I will tell you if their advice is good or not. LOL. I would recommend contacting Circle D or Yank for their recommendation.
03-15-2022, 06:55 PM | #10 | |
03-15-2022, 07:28 PM | #11 | |
03-16-2022, 12:40 PM | #12 | |
Drives: 2014 Chevy SS Join Date: Nov 2014
If I were in your position, I'd have my tuner address that surging.....AND.....I would consider a 2800 to 3200 stall convertor. Brands I'd consider are Yank, Circle-D and Precision Industries (Vigilante). Best of luck with whatever YOU decide to do. KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4 2014 Chevy SS --- 429ci Hydraulic Roller LS3 |
cam, cam conversion, help me, torque converter |
