01-04-2022, 07:25 PM | #1 |
Drives: 2013 Camaro ZL1 Join Date: Nov 2021
Wheel curb rash
I just went over my new to me ZL1 and found some curb rash on my factory black rim. It’s about an inch or so wide and only on the outside lip. I can easily smooth it back out but does anyone know if there is a paint that it can put on it and buff it in to make it look better?
01-05-2022, 10:46 AM | #2 |
Drives: Fast Join Date: Feb 2010
Take it to a paint store and have it matched and put in an aerosol can, you should be able to tape and blend good enough with the can. these wheels have the worst wheel paint ever.
http://www.youtube.com/watch?v=fPvVm...&feature=share
New and improved non-violation sig vid!! |
01-12-2022, 05:26 PM | #3 |
Drives: 2013 ZL1 Join Date: Nov 2018
Do a Google search for "Alloy wheel repair near me" they can fix and paint for probably $100
2013 ZL1 M6, 2.4 pulley and a few bolt ons. 590 wheel and 11.70@122 on a hard tire.
01-18-2022, 12:43 PM | #4 |
Drives: 2013 Chevy Camaro ZL1 Join Date: Feb 2021
Dupli-Color 11 Ounce Satin Black Spray Paint High Performance Wheel Coating
Part #HWP104 Almost perfect match to the stock satin zl1 wheels |
01-28-2022, 12:16 PM | #5 |
Drives: 2010 Camaro SS Join Date: Jan 2022
Hey I was curious how you know that Dupli-Color HWP104 is a good paint match for the wheels? I have a set and have been looking everywhere for information on paint that matches so I can repair some rim rash on my own set. I haven't been able to find anything that's good or solid information but instead just mostly speculation on this forum. Have you used this paint on the ZL1/1LE wheels yourself? Can you give me some details of how you know it's a perfect match? Anything would help because I am at a brick wall.
02-10-2022, 11:51 AM | #6 |
Drives: 2022 ZL1 1LE Join Date: Feb 2022
I use a black Sharpie. Works every time especially for the smaller scratches. Transport company gave mine a 2" gash!
02-28-2022, 05:57 PM | #7 |
Drives: 02 Camaro B4C Join Date: Nov 2016
I picked up 4 ZL1 wheels for my grandson, yes I'm old. They were dinged and rashed pretty good.
Put some time in sanding and feathering the rash and dings. Washed the wheels with a wash to remove the road grime and brake dust. Wiped the wheels with prep solve, sprayed with self etching primer, high build primer, both compatible with aluminum 2 coats each. Then 3 coats of the HWP104 Dupli-Color. They came out very nice. A friend was helping me. He sold automotive paints for 30+ years. He was very impressed with how the paint covered and how smooth it lay. We did the complete face of the wheel. 4 wheels used about 2.5 cans. A trick we used, if painting the wheel with the tires on the wheels place playing cards, over lapping, between the wheel and tire. Eliminate over spray on the tire. Have a few spots that I should have spent more time on but overall they look very nice. Now that the wheels are completely painted we can do touch up if, when, needed. Just remember if you plan to do this preparation is 95% of the job. Good luck Craig
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
03-15-2022, 04:12 PM | #8 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
I got mine a little rashed and ended up getting them powder coated with a bit more gloss in them to ease cleaning
UPSTATE C5 MEMBER
03-15-2022, 10:57 PM | #9 | |
I've used it plenty of times on my wheels, after I sand down the wheel and respray it with the HWP104 I can't tell which have been repainted, and which haven't. Hope this helps. |
03-16-2022, 11:31 AM | #10 |
Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
This.
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
03-17-2022, 02:55 AM | #11 |
Drives: 2013 Camaro ZL1 Convertible Join Date: Apr 2013
Just sanded and painted all 4 rims..
125 JRE 125 RWHP Package
03-20-2022, 03:08 AM | #12 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
Looks beautiful !! Nice .. until you start driving them and it starts chipping off ..
