02-27-2021, 01:37 PM | #43 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
Redline or LS Driven in my opinion. I like the Redline 5w30. A little thicker than most off-the-shelf stuff, more zddp, etc. Stock bottom end still gets a 30wt in my opinion. I doubt your failure had anything to do with viscosity, personally.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // Elite Ultra CC // BMR MM
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
02-27-2021, 02:01 PM | #44 |
Drives: 2012 ZL1 Join Date: May 2017
LS Driven.. This is the oil Hutter Racing pushes. They build lots of high HP engines including NASCAR stuff.
02-27-2021, 06:11 PM | #45 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I'm not saying it's better than the other oils mentioned previously in my opinion, just sayin' it might be ok, even if it's not the best. |
03-01-2021, 02:05 PM | #46 | |
Drives: 2014 ZL1 Join Date: Apr 2018
03-01-2021, 02:31 PM | #47 |
Happy_Dan
Just remember that VR1 had no detergents in it. Meant for race applications.
03-03-2021, 01:25 AM | #48 |
Drives: 2015 ZL1 Join Date: Feb 2020
The cars only brought out and beat on. So I guess it’s pretty much a race car. Oil is changed every 1.5-2k miles. So 5-20 wouldn’t be too bad. I just feel like if I’m not upgrading the oil pump. I at least need a better oil in there. Gives me peace of mind.
787WHP/ 719TQ | Fully Forged Short Block | Custom Spec GPI Cam | DSX aux pump & FF sensor| 1200cc FIC Injectors | Lingfelter 10.0” pulley & ATI damper | RotoFab Intake | ZZ Performance solid isolator | Kooks Headers | Corsa Catback | AFCO dual fan HX | Reinforced IC brick | AEM 3-in-1 Gauge | GPI Tuned | Carbon Fiber WickerBill | Morimoto Tail-lights | WELD S71 + ET STREET R’s
03-03-2021, 04:51 AM | #49 |
Drives: Chevrolet camaro zl1 Join Date: May 2019
In the same boat. Spun a rod bearing and in the process of rebuilding right now. I too was running mobil 1 5w 30. I was not even getting on it just cruising and heard the knocking. I did notice for about a month before the oil pressure at idle only showed 14 to 15 psi when warm.
2014 Sliver ZL1. Built engine, Stage 1 Frankenstein heads, Magnuson, SW long tubes, AFCO H/E, She Gone cam, flex fuel sensor, meth injection. 820rwhp e85.
03-03-2021, 01:07 PM | #50 | |
fo'shizZL1
03-03-2021, 01:29 PM | #51 |
Drives: zl1 blk Join Date: Nov 2017
there are many reasons these lsa's have bearing issues.. i have studied it some .. the lsa is set up with tight tolerences from factory with the forseen concept that the aluminum motor will grow when heated up. Aluminum motors expand and contract more than a cast iron block. I feel the lsa's get some premature wear upon start up and if the car is not up to temp before seeing some load may be a contributing factor.. I think we should gather some data.. like which bearing/pics, oil specs, oil psi, start up treatment,mileage. etc... might be able to get a better understanding of whats causing these issues. but there are a lot of factors to consider ...
03-03-2021, 02:04 PM | #52 | |||
But I guess I’ll be at least making sure my factory oil pump is good. If it is. I’ll leave it alone. If not. Then I may upgrade to HV one. Regardless a better oil is going in it. With e85 dilution. I feel like 5-30 M1 isn’t going to cut it. And have my Rev limit moved from 7k back down to like 6500. Quote:
03-03-2021, 09:41 PM | #53 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
IMO 7000 rpm is way too high for a stock LSA with the stock valves which are very heavy. It also spins the SC excessively high and generates a lot of heat which translates into high combustion chamber temps which is never good. I've run Mobil 0w-40 in mine since 2014 when I swapped cams. It's a good oil imo. 12.4 AFR at WOT is on the lean side and with too much timing can cause failures. Even with TF heads I keep mine on the conservative side for AFR and only shift at 6500 rpms. I've been down the stroker road before with my previous set up and it gets expensive fast.
03-03-2021, 10:40 PM | #54 | |
03-04-2021, 08:04 AM | #55 |
Drives: 2015 zl1 m6 Join Date: Jan 2020
I replaced my oil pump to a 10355 for my truck . From what I was told by tsp that stock oil pumps tend to cavitate and starts to aerate at Rpms above 5500rpms .
When it’s time to do my z I will be replacing my oil pump , as I’m changing the cam right from the get go, I’ll already be there , plan on cutting cross member and using that kit I bought from here to modify cross member to get the oil pan out . To me it’s just that much more extra insurance besides the pump is only like 200-300.00 from what I remember . I’ve also always ran driven ls-30 and I do have a mm catch can aswell . I’ve been running cam and. Other bolt ons for my truck for over 3 years now |
03-04-2021, 08:07 PM | #56 |
fo'shizZL1
That is accurate. Here is the graph:
