TireRack
Old 07-27-2017, 12:20 PM   #85
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Originally Posted by KillboyPowerhead View Post
Sway bar links don't need to be timed as they are a ball-joint type joint. When you put on the coil-overs/springs you'll be removing the links so when you tighten everything back up simply bolt down tight with some blue loc-tite.
Factory links are not adjustable; you can get adjustable front links which I guess would be good for racing so you can corner-balance the car, but otherwise I wouldn't bother; for the rear if you want to adjust them you need to cut them - the ideal mounting position for the rear bar is centered over top of the mount of the control arm (link pointing straight up and down), so if you lower the car you could cut the link shorter but be careful how much you cut off!
Edit: just noticed you have a 2010. If you don't have the new style rear bar I highly suggest going that route. What I said about cutting the link applies to the new style links. I guess with the old style bar your adjustability is pretty limited even with modifications.
I have second version of pedders endlinks. They are adjustable. No cutting. Just spin heads to adjust length.
Old bar has 3 holes for adjustments. I will keep an eye on it as I install the coilovers.
Update...Build in process, Forged Rods, Pistons and rings, Johnson Lifters, NOVI1500 ECS SC, 13lb boost or more, LS3 Conversion 114/228/241 COMP CAM, Frostbite 4 row Aluminum radiator, 6L80 built, Circle D 6L80 PRO SERIES MULTI 258MM 2D, Stock 3.45 gears, 1-7/8 American Racing Headers w/HF cat, X-Pipe, Lingenfelter dual fuel pump, E-85 flex sensor, ATI super damper pulley, Ported TB, 160 therm, Trans cooler, Pedder's sways/end links/sub frame bushings, BMR trailing arms & toe rods, Coil overs. HP/TQ pending
edog is offline   Reply With Quote
Old 07-26-2018, 03:45 PM   #86
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Originally Posted by K32 Camaro View Post
Still calling for this to be stickied!
It has been Done!
Old 07-27-2018, 09:11 AM   #87
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
It has been Done!
...great thread.
Old 07-27-2018, 04:12 PM   #88
REA78
Drives: 2013 SS RS VERT
Thank you for this thread!! Just took this info and gave to tech at Chevy dealership here in San Antonio. They even allowed me to go in the back and watch them do the timing of the bushings.
REA78 is offline   Reply With Quote
Old 07-27-2018, 04:58 PM   #89
farm rat
farm rat's Avatar
Drives: 2011 Vistory Red 1LS
Now we don't have to use the search function anymore
The Original Farm Rat
2011 1LS M6 Victory Red
Sold
1967 Coupe Green and White
1969 SS 396 Hugger Orange
1969 Z/28 All original White with deluxe interior
1970 RS Blue
1978 Coupe Fugly Green
1978 WS-6 Trans-Am Factory 4 speed
1985 IROC-Z Red
farm rat is offline   Reply With Quote
Old 07-30-2018, 12:30 PM   #90
BMR Sales
BMR Sales's Avatar
Drives: Race Car
if you had used the Search Function to look for this Thread in the last year, it would not have worked, as the Thread was deleted and we finally got it back up last week!
Thanks to the Admins for bringing it back!
Old 02-23-2019, 10:05 PM   #91
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Originally Posted by Avalnch View Post
Do the aftermarket components that are poly/delrin with an aluminum sleeve need to be "timed"?
Was this ever answered? This is a really good question!
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 02-23-2019, 10:46 PM   #92
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
They do not.
Old 04-24-2019, 11:54 PM   #93
SS 310H55A
Drives: 2014 Camaro SS
Timing Bushings when lowering (How to)
2014 SS | MGW Flat Stick shifter | Raceseng Slammer shift knob | Z/28 spoiler and grill
SS 310H55A is offline   Reply With Quote
Old 04-25-2019, 12:03 AM   #94
dru21281
Poly and Derlin bushings do not need to be timed. They have a metal sleeve that the bushing rotates on(free floating), oem rubber bushings are attached.
Sent from my Pixel 2 XL using Tapatalk
dru21281 is offline   Reply With Quote
Old 04-17-2020, 10:02 PM   #95
imponte
imponte's Avatar
Drives: '10 Camaro SS
Hi guys. I didnt this procedure after install hotchkiss 1" spring. But did alignment. Car pulling left now. I cant solve this problem after several alignment shop visit. My current alignmnt:
Front camber: -1.05 , -1.2 caster: 5.55 , 6 toe:+2.2mm , -0.4mm
Rear camber: -0.35 , -0.35 toe: +1.6 mm , +1.4mm
What is your thoughts?
imponte is offline   Reply With Quote
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 06:53 PM
Timing bushings gtfitter597 Suspension / Brakes / Chassis 41 07-09-2014 11:02 AM
Put More Power To The Pavement With Pfadt Engine Mounts And Differential Bushings!!!! Apex Motorsports Transmission / Driveline 28 11-27-2010 10:46 AM
clunking after bushings and lowering rtkjadams Suspension / Brakes / Chassis 12 10-01-2010 10:56 AM
Urethane Bushings from Energy Suspension Bewenched Suspension / Chassis / Brakes 1 04-30-2010 05:12 AM
