TireRack
Old 02-26-2019, 09:49 PM   #15
scv_guy
scv_guy's Avatar
Drives: 2010 Camaro SS
Pm sent
scv_guy is offline   Reply With Quote
Old 07-08-2019, 08:22 PM   #16
vader87
vader87's Avatar
Drives: 2013 Camaro ZL1
Interested, can you pm me the info?
2013 ZL1/A6: CNC'd SC w/lid spacer, 2.35 upper, 9.45 lower, BTR Stage 3 Cam, Wilkes Performance CNC'd Heads, 1050cc injectors, DSX Aux pump, 1 7/8 headers, 102 TB, JLT CAI, Killer Chiller, LSX Concepts race drive, Flex Fuel Tune. 12.8 lbs. boost 753/724
vader87 is offline   Reply With Quote
Old 09-16-2019, 05:49 PM   #17
CFD
Drives: 2SS/RS L99 BLACK
For this inquiring. I will be machining more flanges this week.
Old 09-17-2019, 08:54 AM   #18
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Flanges
How much will the flanges run?
Orange Krush II
Old 09-19-2019, 05:26 PM   #19
CFD
Have a few sets of crossmember flanges finished.
Old 12-28-2019, 02:22 PM   #20
KenBaker
How much? Could you please provide a link where these can be purchased? Thank you
KenBaker is offline   Reply With Quote
Old 01-05-2020, 09:17 PM   #21
Brewster
Drives: 2015 Camaro 2SS
Hi CFD, I am interested in purchasing a set of these. Can you contact me with details for purchase?
Brewster is offline   Reply With Quote
Old 01-26-2020, 07:55 PM   #22
g1o1101
g1o1101's Avatar
Drives: 2011 Camaro 2SS L99
Hi all.
Here is a quick guide on installing CFD cross member flanges.
The sketches below are not to scale but are for reference.
Using a sawzall, cutoff wheel etc. find midpoint between the holes on the cross member as indicated in the first sketck. Make this cut about 85deg from the back of the cross member. When this cut is made the flanges should angle in slightly as in the first picture. Once the cross member is finished this will allow it to be put in place from back to front without any difficulty yet allow a tight and secure fit.
After cleaning and prepping the area you will be working with for welding,install a flange on each end of the frame stub and one on each end of the cross member section you cut out. The inner hole of the flanges are slightly tapered to match the formed cross member. put the cross member in place with the flanges centered over the cuts to test fit it. If all seems good remove the flanges and grind back the top of the frame stub about 3/16". The reason for this is once the flanges are installed on the frame stubs you will be able to weld the bottoms and sides but not the top, with the top cut back you can now weld the top from the inside of the flange. Be careful not to get any weld on the mating surface of the flange, if you do, file or grind it flat so the flanges mate squarely.
Now that everything is ready, again install the flanges and cross member section on the car, bolt the flanges together securely and verify they are centered over the cut line. Tack weld all 4 flanges in place. You should be able to unbolt the mid section and remove it to verify fitment. If all is good re-install the cross member, again bolting it in place securely finish welding all accessible areas. Remove the cross member and finish welding as needed.
The newly made cross member section should now be able to be removed and installed without any difficulty and should mate to the frame stub flanges fully for a strong, easily removable cross member.
How much for these flanges ? need to drop my pan and need a set. please contact me giovanni.arriaga01@gmail.com thanks!
g1o1101 is offline   Reply With Quote
Old 08-16-2020, 09:23 PM   #23
Sharp406
Drives: 2010 SS/RS
You got a set I could buy?
Sharp406 is offline   Reply With Quote
Old 05-10-2021, 02:57 PM   #24
rogerm
Drives: 2012 camaro, 68 gto, 90 454ss, 57 b
how can i order these flanges
rogerm is offline   Reply With Quote
Old 05-10-2021, 03:15 PM   #25
gtstorey
I don't think CFD is on here a lot anymore so you probably need to send him a private message and see if he has any. Here is his build thread;
https://www.camaro5.com/forums/showt...1#post10988311
Old 05-10-2021, 03:41 PM   #26
CFD
Lol. I'm still on here daily.
Old 05-10-2021, 04:04 PM   #27
gtstorey
Then where are your project car updates?
Old 05-10-2021, 04:07 PM   #28
CFD
I've been driving it more than working on it. Lol. After putting the new cam in it I haven't done anything to it, it's running great and I'm busy at the shop
