Old 06-18-2019, 01:52 AM   #15
GunMetalGrey
GunMetalGrey's Avatar
Drives: Track prepped 2018 Camaro ZL1 (a10)
Originally Posted by TrackClub View Post
Yes indeed. Immediately after you park after a session, check all 4 tires with a reliable gauge. I like Longacre brand. If you see any pressures above recommended max hot - bleed them to recommended hot. Repeat the procedure after each session. At the end of the day, dont forget to check cold pressure for drive home as you may be much less than recommended 32 and need to add some.
Personally i start at 28 cold so the tires dont take much to "come in" usually a lap or two max. Then i keep them at 36 hot. A bit higher is ok too and will depend on how far the scrub line extends to the outside of the shoulder. If it goes beyond the little GoodYear symbol you may have to run it a bit higher, try 1-2 psi. If the wear is short then reduce.
This may depend on a track, as well as how much you slide the car, etc. Either way i dont go much below 36 with G3s. Cheers!
Thanks!
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 06-18-2019, 09:15 AM   #16
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
Originally Posted by GunMetalGrey View Post
Thanks for that info, I'm looking forward to seeing what my temps are at VIMSC.
What pyrometer unit will you be using?
NPP, MRC, Tinted side & rear reflectors, OEM ZL1 Rockers / 3rd Brake / Darken tail lights, OEM Blk rear splash guards, Satin hood wrap, Fuse pull, Sound tube delete, Cat delete, Ported 95 TB, Ported MSD IM, Dry RotoFab, ARH 1 7/8 headers, E85, "Performance Dyno" Tune, BMR "pieces", "Track" alignment, Hawk DCT-70/70's w/SRF, Goodridge lines, Ti shims, Red powdered calipers, 18" APEX SM-10's w/ Pirelli DH's, FE4 Vert swaybars, Brake cooling ducts, ATI 10% UD, Vorshlag camber plates, OEM 1LE Splitter w/APR Ext., Velossa BIG MOUTH Ram Air, CF QA1, ZLE brakes(F)
driven2exceSS is offline   Reply With Quote
Old 06-20-2019, 06:56 PM   #17
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
I've tried 36 hot and still too far away from the Goodyear symbol. I'm trying 34-36 hot this weekend which is only going to be 95 at COTA. For sure you want a accurate pressure gauge to use. The Longacre one I have is +/-0.2 psi
carguy55 is offline   Reply With Quote
Old 06-20-2019, 07:16 PM   #18
driven2exceSS
Mmmm IDK think that is too low. Maybe the track you're on too, and tires not being pushed to roll as much. Likely they will get rather greasy pretty quick. I've been told before not to adjust for tire "wear" based on air pressure alone!! That means you will need a pyrometer probe, not just a air pressure gauge. This will tell you if your alignment specs and pressures are appropriate for your driving style for that particular track. The next track will most likely be needing different specs, but most of us can not afford to deal with such particulars to that level.
Old 06-23-2019, 10:21 PM   #19
GunMetalGrey
My mistake, meant pressure.
What meter do you recommend if I want to start measuring tire temps?
Old 06-24-2019, 08:03 AM   #20
ZapperZ
ZapperZ's Avatar
Drives: 2018 ZL1 1LE 2022 GMC AT4 HD
Front 39psi hot
Rear 37psi hot
Sounds like a lot of pressure but worked very well for me
ZapperZ is offline   Reply With Quote
Old 06-24-2019, 08:19 AM   #21
Snakebt6
Drives: Rally Green 2020 ZL1 1LE A10
Based on scrub lines alone this tire (Left Front) is over inflated, the pressure was right at 38 and I saw 39 occasionally. So id imagine if I was at 37 ( I believe that's the recommended hot pressure for RC driving) It would be right at the top of the wing or pretty close.
It was really hot that day by the way and started with 30 PSI.
Snakebt6 is offline   Reply With Quote
Old 06-24-2019, 08:42 AM   #22
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I see feathering all the way into the lettering on my front SC3s. I know the pic doesn't show the sidewall, but look at the outside edges. You guys can push so much harder...
TheRealJA105 is offline   Reply With Quote
Old 06-24-2019, 10:37 PM   #23
driven2exceSS
Sorry for delay been up at Mont Tremblant and spotty service. I honestly do not know what pyrometer to recommend. I have a cheap infrared one, and I had a guy that does my track alignment check mine with a probe pyrometer at my last event to check the latest alignment spec's and wear. Sorry!! I'll ask what unit he is using tomorrow...
Old 06-24-2019, 11:56 PM   #24
TrackClub
TrackClub's Avatar
Drives: 2020 SS 1LE (previous: 2017 SS 1LE)
Agree!
TrackClub is offline   Reply With Quote
Old 06-25-2019, 12:00 AM   #25
TrackClub
TrackClub's Avatar
My fave venue Have bags of fun!
NB i did have a "proper" pyrometer. Never left the box lol!
I find managing by pressure and wear marks to be completely reliable. Imo anyway.
Old 06-26-2019, 02:16 PM   #26
TheRealJA105
Drives: 2013 C6Z06
No wings left here! Still running these tires btw.
Old 06-26-2019, 03:57 PM   #27
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Do you risk a blowout if you run tires much past the cords showing?
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers)
Previous:
18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust)
16' F80 M3 (Ohlin R/T Coilovers)
13' Audi TTRS (APR Stage 1, MSS Springs)
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
TRZ06 is offline   Reply With Quote
Old 06-26-2019, 04:17 PM   #28
Badmojo
aka BeastZL1
Badmojo's Avatar
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra
I run:
Front 26 PSI Cold
Rear 27 PSI Cold
Track alignment per track supplement.
Target is 35 PSI hot.
GY SC 3's will wear closer to the sidewall mark as they wear down. The tires start square and will round the outside edge after 5+ track days.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Badmojo is offline   Reply With Quote
psi, sc3, scrub-lines, tire
