03-25-2018, 09:56 PM | #1 |
Quarter panel wheel/tire gap normal?
Can someone confirm that this 1.75" quarter panel to rear tire gap is normal on a 2018 non-1LE MRC 2SS? I'm inexperienced, but it looks a bit too much to me.
The car has neither the 1LE suspension package (LPO: SCJ, part # 84233245) nor the sway bar upgrade (part # 84242386). Perhaps the answer is that it should, heh, but I'd like to be enlightened first. Thanks in advance for the info.
03-26-2018, 05:14 AM | #2 |
That's a lot of gap. You hadn't recently raised the car on jacks had you?
03-26-2018, 06:35 AM | #3 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
Pardon my ignorance, but how would that affect things?
This is that witty and clever statement that makes you chuckle.
03-26-2018, 07:24 AM | #4 |
Most cars will ride higher than normal for a few miles until the suspension settles after the wheels are jacked off the ground. The suspension is going from un-sprung weight while in the air to sprung weight once the tires are back on the ground so there is a settling period until the car is back to normal ride height.
FWIW - my non-MRC SS rides at the same height as the OPs MRC equipped car (I just went out to the garage and measured). At the last CamaroFest I asked Al O. and the rest of his Camaro engineering team if they would consider a lower ride height for future production as I thought the car looks like a pick-up truck with the stock ride heights. The basic answer I got was they set the ride height where it is due to factory construction constraints and that if I wanted a lower ride height I should go buy the GM spring/strut package ($1500 plus labor) in the Gm performance catalog. SMH
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) Last edited by SSDan; 03-26-2018 at 08:10 AM. |
03-26-2018, 08:58 AM | #5 |
Sure, why not?
SSDan, thank you for the explanation!
03-26-2018, 10:00 AM | #6 |
Nope. Last time it was raised was over a week ago (at the dealership), so even if that were the cause, the suspension should've settled by now, or am I wrong?
03-26-2018, 04:39 PM | #7 | |
Overall ride quality doesn't seem to be affected by the height, or perhaps my butt isn't sensitive enough yet. I've given some thought to that suspension track pack, but there are other priorities at the moment (basically, wifey gets a few budget slots for a while )
03-26-2018, 05:43 PM | #8 |
Drives: White 1LE Join Date: Dec 2016
Road car not a race car.. normal
Sent from my SM-G955U using Tapatalk |
03-26-2018, 06:00 PM | #9 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
gotta remember, they make cars to travel not only the smooth roads and stuff, but also cities with potholes, bad suburban areas, or if you live on a farm road for example. even the GM lowering kits only lower 20mm, which is barely 3/4 of a single inch. the ZL1 1LE only gives you 10mm of lowering (1/2 inch is 12.7mm).
Don't sit around and watch everyone else live YOUR dreams...DO SUMPT'N
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
03-26-2018, 06:42 PM | #10 | |
Drives: 2016 SS w/2SS A8 Blue Velvet Join Date: Dec 2009
Never grow up, it's a trap!
03-26-2018, 07:01 PM | #11 | |
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears 476 rwhp/440 rwtq (sold) |
03-26-2018, 08:12 PM | #12 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
Just put some fat chicks in the back and call it a day
Sent from my SM-G965U using Tapatalk
Bone Stock |
03-26-2018, 08:15 PM | #13 | |
03-27-2018, 07:04 PM | #14 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
