04-10-2024, 02:43 PM | #1 |
Drives: 2011 Camaro SS Join Date: Jul 2017
Trans cooler fan wiring
I'm hooking up a stack plate trans cooler with a fan. I wired it to the main engine fan so it comes on with the fan setting in the tune. That's usually around 180ish degrees. Its a small fan. 6 inch diameter and doesn't pull that much power. Thoughts on this? Yay or Neigh?
04-10-2024, 02:54 PM | #2 |
Are you asking about the electrical aspect or the cooling aspect?
04-10-2024, 03:46 PM | #3 |
The electrical aspect.
04-10-2024, 04:25 PM | #4 |
I would put in a relay triggered by the main coolant fan voltage vs just pulling current directly from the main fan wiring.
04-10-2024, 05:38 PM | #5 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Agreed, ALWAYS run a load like a fan through a relay with a fused 12v source. Relays are your best friend when adding accessories.
04-10-2024, 07:33 PM | #6 |
My fan plug burned with just the stock fans running on it. I would definitely just tap into the fan feed as trigger for an additional relay with a separate power source.
04-10-2024, 09:27 PM | #7 |
Ok. I have a relay that I'll wire up.
Thread Tools | |
