03-21-2024, 07:29 PM | #1 |
Drives: 2013 zl1 Join Date: Apr 2023
Upgrade Throttle body or not?
So I am going to do my second set of mod upgrades [2013 zl1) and my buddy mentioned adding Throttle body upgrade (Nick Williams 102 is what my mech has in stock).
Question is…will I notice that much of a difference for the cost? ($700 installed) Background Once this next round is done…I will have had done the following - ported blower, upgraded pulleys, E85 upgrade, new injectors, cam, long run headers, new clutch, 2 tunes…should end up at approx 800rwhp Thanks for advice in advance! |
03-21-2024, 08:15 PM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
At that power level you should notice a difference. I picked up something like 40 whp going from a ported 90 to a 103 for my Whipple.
Sent from my Pixel 8 Pro using Tapatalk
03-22-2024, 11:59 AM | #3 |
Hey Larry, lol, I just saw this and was going to mention you and what you did gain from the 102 I sold you!! Awesome brother!!
03-23-2024, 05:53 PM | #4 |
Thread Tools | |
