02-19-2023, 02:00 PM | #1 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
LS3 Heads and other good stuff!
I have a good condition set of OEM LS3 heads with upgraded Cam Motion Spring set. 700.00
1LE Front /Rear Shocks and Struts w/Hotchki 1 inch springs. 500. Cam motion LS3 stg 3 Cam Used for about 10k miles. 250.00 LS7 water pump. MAKE OFFER. Brembo Front Caliper with new pads. Make reasonable offer. Not pictured Left side 4 coil packs with bracket. Make offer. Last edited by rich2342; 02-19-2023 at 02:33 PM. |
02-19-2023, 04:06 PM | #2 |
Drives: 2010 1SS Join Date: Aug 2015
What core & lift options on the CM-3? Any dyno results?
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
02-19-2023, 04:09 PM | #3 |
222/230 .595/.595 lift 117 lsa if I recall. Put down 447whp 440 wtq. Great sporty cam with instant response and pull low to mid upper rpms.
I had a few nice kills with it in my 6spd. |
02-19-2023, 04:15 PM | #4 |
Nice.. mine is a bit overkill for my use and looking for something a little more mild mannered with low end response. Any chance you know the core type 5150 or 8620? I assume it is a 3 bolt?
02-19-2023, 04:33 PM | #5 |
This might be the one for you. It is not rowdy. Instant torque off the line. Very fun in that regard.
I am pretty sure it is the hardened core. I have never gotten softer materials due to my fear of scoring etc. |
02-19-2023, 04:38 PM | #6 |
Thanks.. if you could verify the lift and core that would be great.
02-19-2023, 04:47 PM | #7 |
Ok, apologies. It is the 5150 core. My second cam I got 8620.
Specs are attached high lift version. |
02-19-2023, 04:54 PM | #8 |
Thanks.. I'm tossing a few things around so will let you know if I decide.
02-21-2023, 09:52 AM | #9 |
Bump
03-09-2023, 08:39 PM | #10 |
Bump
03-16-2023, 12:42 PM | #11 |
Cam motion camshaft has been sold.
The rest is still available. |
04-10-2023, 07:46 AM | #12 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
Heads still available
04-10-2023, 08:10 AM | #13 |
Heads are sold! Other parts still avail.
Thanks |
04-12-2023, 01:19 AM | #14 |
Drives: 2011 Camaro SS A6 Join Date: Mar 2023
PM sent
cam motion, camshaft, hotchki, ls3 heads, suspension |
Thread Tools | |
