Old 11-01-2021, 08:58 AM   #1
96gt4.6
Drives: Whipple'd Mustang S550
Magnuson Heartbeat Kit Fuel Injectors
Looking for a little help before I pull the rail and existing injectors....
I'm needing change out the supplied injectors for some larger ones on this Magnuson Heartbeat kit, but i'm not sure if it takes some different size injectors physically/body wise or not from whatever size the car used N/A.
I have a set of FIC's in mind, and they state 2010-15 Camaro SS/ZL1, but I'm not sure if the manifold/rails on this Maggie kit will accept them drop-in or not.....
Waiting on Magnuson to get back to me as well....but sometimes it can take a while. Thank You!!!!
'17 Whipple'd S550 Mustang, Stage 1 (750hp) kit, all stock otherwise less M/T ET Street Radials/VMS Rear Drag Pack Only. 643 RWHP (dynojet). 10.92@128, 1.59 60' (2800 ft corrected D/A). 91 Octane+Boostane Octane Booster.
Many other turbo LS/Ford Builds to date, see my YouTube channel
YouTube Channel: https://www.youtube.com/channel/UCr7..._as=subscriber
96gt4.6 is offline   Reply With Quote
Old 11-04-2021, 05:41 AM   #2
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
I swapped mine out to ID1050X's when putting mine together. I bought ones for a SS and they worked perfectly. Assuming you are using the stock rail that came with the heartbeat kit from Magnuson.
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 11-04-2021, 08:32 AM   #3
96gt4.6
Thank you sir!
I have some FIC 850's on the way. I did end up getting a reply from Magnuson, and they also confirmed that the ZL1/NA SS injectors will fit.
The kit comes with LS9 Injectors I was told.
Old 11-04-2021, 11:13 AM   #4
Ashen 6.2
Ashen 6.2's Avatar
Thank you sir!
Awesome. The fuel rail they supply is supposed to be LS9 as well.
Old 11-04-2021, 12:14 PM   #5
96gt4.6
^ You are correct as well sir, I just looked one up and that's definitely it!
Thanks for the help. Looking forward to getting close to the 600 WHP mark on 98 Octane with this setup. Ran out of injector on 6psi/Pump gas.
This car has:
Maggie Heartbeat Kit
TSP Stage 1 S/C camshaft
Full Exhaust
ZL1 Pump
Pump Voltage Booster
Put down 525 On the stock L99 Cam/8psi/91 Octane prior. The cam upgrade and 98 Octane, I'm hopeful we'll get to 600 WHP on 9psi.
Old 11-05-2021, 05:22 AM   #6
Ashen 6.2
Ashen 6.2's Avatar
This car has:
Full Exhaust
ZL1 Pump
Awesome & should be there I would think. Post the results when you get time.
Old 12-05-2023, 04:54 PM   #7
deano9666
deano9666's Avatar
Drives: 2015 2SS/RS
That's sounds exciting, good wheel numbers, wow.
My heartbeat with longtubes, no cats, npp exhaust 556whp, 518tq, researching next step, any suggestions ?
deano9666 is offline   Reply With Quote
Old 12-07-2023, 06:11 AM   #8
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
A camshaft would help out significantly, as would turning the boost up a little bit. Based on fuel pump and injector size, you could also run E85.
Switching to E85 was worth almost 60whp on my car.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 04-04-2024, 06:27 PM   #9
deano9666
deano9666's Avatar
Drives: 2015 2SS/RS
-Scott
I really want to jump to my stage 2 , just ordered 1000cc injectors, researching fuel pumps atm. just trying to figure out the pulleys now as Magnuson tells me I might have to under drive !
Old 04-08-2024, 04:38 AM   #10
Ashen 6.2
Ashen 6.2's Avatar
What psi are you looking to get too? Are you using the single 6 rib belt drive with your set up? if so, the single 6 rib setup will most likely start having belt slip with a 3.40" (86mm) supercharger pulley, especially above 7K rpm.
