04-14-2019, 12:46 PM | #1 |
Drives: '10 ABM 2SS/RS M6 Join Date: Dec 2014
rear cradle woes
ok so heres my problem, i have a '10 ss m6. the car doesnt wheel hop at all with the full bmr rear suspension on it including diff bushings and upper control arm mounts. however after my recent cam install when i do a hard 2nd or 3rd gear pull the ass end wags back and forth so bad i practically have to get out of the throttle. im assuming this has to be the stock subframe bushings that i never replaced but i figured i would check here first to make sure im on the right track.
Kooks | SW | GPI | BTR | ADM | Bo White TB | BMR | FE6 | Hotchkis | 3.91s | Truetrac | Pegasus
04-14-2019, 06:11 PM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Stiffer rear cradle bushings will most certainly help keep the rear planted while accelerating, if that's what you're asking. I can recommend solid aluminum bushings by Pegasus - they make a huge difference.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
04-14-2019, 06:17 PM | #3 |
Drives: 2010 SS L99 Join Date: Sep 2018
I agree
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
04-14-2019, 07:13 PM | #4 |
just trying to be sure thats whats causing my problems, i cant think of what else it could be
04-14-2019, 07:26 PM | #5 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I'm sure the added power has a lot to do with it. I'm sure cradle bushes will help....and maybe some sticky tires.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-14-2019, 09:10 PM | #6 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Cradle bushings will keep the subframe from unevenly moving, but the cause is likely your diff/limited slip. The truetrac made a big difference for me. The car just drifts when it breaks loose, rather than a back and forth steering affect.
Also the 1LE/ZL1 toe links keep the wheel hub in place fore/aft by replacing the rubber bushing with a spherical bushing. Cheaper/easiest to install.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
04-15-2019, 09:45 AM | #7 | |
i already have bmr toe links, trailing arms, upper control arm mounts, sway bars, diff bushings, 1le shocks and shock mounts
04-15-2019, 05:52 PM | #8 |
Drives: Miss Con Ception Join Date: Aug 2016
I am on stock power so I installed inserts before I did anything else.
Took all that wishy-washy out of the ass and were relatively easy to install. With more power you may need poly or solid bushings.
2011 1SS/RS LS3 CGM
04-16-2019, 10:06 AM | #9 |
Do Pegasus bushings ever go on sale?
04-16-2019, 10:33 AM | #10 |
Drives: Z06 wannabe Join Date: Feb 2015
Pegasus bushings were awesome for my car, good price!
Apex Focused
04-16-2019, 10:40 AM | #11 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
I don't have solid bushings, but if I had it to do over again I would probably go that direction. The reason is that it was a chore to get the poly bushings installed in the cradle. Much more difficult than I had imagined. I haven't heard the same issues with solids, so all things being equal I would go for the easier install.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
04-16-2019, 10:45 AM | #12 |
I think the reason I never did subframe bushings was a combination of price, not wanting to mess with getting the old ones out, and honestly the rear end movement was never that bad. So getting the rubber bushings out isn’t that bad?
04-16-2019, 01:04 PM | #13 | |
Basically, you need to lower the rear cradle enough to fit a 1" wide socket above each bushing, place the socket on top of the bushing, centered, and jack up the cradle (using one jack to support the cradle at the differential and one to push up on the cradle near the bushing), and with the weight of the car on the socket/bushing (so lift the car off the jack stand that you'd probably have near the rear wheel) heat the cradle around the bushing with a torch. Eventually the bushing/glue will get hot enough to melt, and with the weight of the car on the bushing it will slide out. Send me a message if you want more details but that's the gist of it. I'm pretty inexperienced in general with car/mechanical stuff and pretty much only went by videos and DIY guides and I managed to do it myself in the driveway, so you can do it too! Getting the new solid bushings in is super easy, just make sure to clean out the bushing holes (I used a knife while the glue was hot to scrape it out), and throw the new bushings in the freezer so they shrink. If they are being stubborn to get in, make sure to centre them in the hole really well then just jack up the cradle against the frame to push them in.
04-16-2019, 01:43 PM | #14 |
Thanks for the info, I had planned on using the socket method to get the old ones out.
Thread Tools | |
